Brake Problem
Old Jan 5, 2005 | 04:56 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by tdocz' date='Jan 4 2005, 04:08 PM
I had this vibration problem on driving. It was -3 F . It went away when the tire warmed-UP
[snapback]75577[/snapback]
No vibration on driving just braking.
Ching-Ho Cheng
Old Jan 5, 2005 | 05:21 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by urbo73' date='Jan 4 2005, 04:02 PM
Rotors can also warp if the wheel bolts were torqued incorrectly, to very high values. All bolts should be at around 120Nm.
[snapback]75572[/snapback]
I used 88 Ft-Lbs to torque my wheel bolts. That should be close to 120Nm, right ?
Ching-Ho Cheng
Old Jan 5, 2005 | 09:27 AM
urbo73's Avatar
Nm x .738 = ft/lb
So, 88 is close enough!
Old Jan 7, 2005 | 06:02 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Went to dealer this morning, and the tech. was driving my car with me. He confirmed the vibtration and said that it was due to the rust on the pads and rotors.
He told me that the vibration will be diminished by itself over time. He also told me that dealer can replaced the rotors for me but I will get charged. The replacement is not covered under the warranty because it is due to corrosion.
So driver beware .... brake rotors/pads replacement only be covered under warranty if it is worn out under normal use NOT corrosion.
This morning, the vibration is much less than before, but is still there.
Ching-Ho Cheng
Old Jan 7, 2005 | 07:59 AM
soc_fans's Avatar
I have the same problem sometimes too. Especially when i tried to brake in high speeds. Does this occur only on 530i ?
Awest91
Sep 17, 2022 11:05 PM
UltimatePeter
DIY: Do It Yourself
Sep 28, 2015 09:12 AM
2004_545i
Apr 8, 2015 04:01 AM
Sakru
Mar 26, 2015 09:26 AM
lc holmfirth
Mar 22, 2015 10:28 AM
