Brake pedal - no start
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Every time we start our 528i's, we have to have our foot on the brake pedal or the car doesn't start. How often does the brake pedal switch break causing the vehicle not to start?
When the 528i doesn't start,many guys are examining the Intelligent Battery Sensor cable or the fuel pump control unit, but no one is examining the brake pedal switch.
What is the general life cycle of the brake pedal switch?
My Ride: 535i 6-speed
Some cars require the brake pedal to be pressed before allowing the starter to engage. Not sure if the 528i is that way or not.
My Ride: 2008 535xi
Engine: n54
I don't think I've ever heard of anyone having the brake pedal switch break.. however, I've had one back in the day die. It's a pretty simple switch... and you can test it yourself by seeing if the brake lights turn on
They might have tapped it and saw the lights and moved on so fast that you didn't realize it when they were troubleshooting for you.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
In BMWs it is required to press the brake to start the car. No one checked the brake switch because it doesn't go out. Brake switches rarely go out in any car unless there is a manufacturer defect in the make. I think BMW has perfected the switch since it is something they have required for a while. I can't speak of cars over 250k miles but none that I know of have failed.
Model Year: 05 530i
Engine: 3.0 M54
I would assume the OP has an automatic having to press the brake pedal. Every manual owner knows they have to press the clutch to start the car. I didn't think I had to state the obvious.
Speaking of manuals... I once had an interesting issue on my E34 manual...the clutch engaged switch was out of adjustment (thought clutch was pressed all the time). The only resulting issue was that I could not engage the cruise control...because the clutch must be disengaged for cruise to activate.
I was trying to clear the confusion in other readers minds and mine also.
Respectfully, Bob p..
Model Year: 05 530i
Engine: 3.0 M54
I didn't assume he did not know the brake had to be pressed. I was following up with his switch question. I started by stating what BMW requires and since they require it why the switch is almost never the issue. Maybe you read my response wrong.
Salut, Bob P.
