BRAKE LIGHT MALFUNCTION
Has anyone ever seen "right brake light malfunction" error message come up...
anyone have any ideas on what that means (my brake lights still work fine) and how to reset the message?
thanks!
thanks!
BMW Bulb errors often result when the bulb base / socket are dirty, lose, or have even the slightest amount or corrosion. And be certain that silver base bulbs are used. The car measures resistance in the circuit and is very very fussy!
The error will go away when the cause is removed.
thanks!
thanks!
I will try that..do you know if I have to take off the outside plasic cover to check the bulbs or can i pull them out from inside the trunk?
Originally Posted by GENEaTALS' post='753796' date='Dec 27 2008, 07:57 PM
you can get to it from the trunk..check you manual on how to get to the bulb ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Awest91
09-17-2022 11:05 PM
TexaZ3
05-06-2015 09:54 AM
