Boost pressure in diesels
My Ride: -04 530D
I have not found conclusive information about boost pressures in BMW diesels from net. Some say that 535d have 2,85bar boost, but that sounds high, comparing information that 530d should have about 1,8 bar.
I would be interested about information of all engines. Maybe that could be added to motor information pages then too.
This is only "nice to know" information and will be used in conversations in local bar, with other petrol heads!
Skaffa
Skaffa
I would be interested about information of all engines. ? Maybe that could be added to motor information pages then too.
Skaffa
Skaffa
[snapback]174689[/snapback]
but i don't have info about this...yeah 2,85 sounds high also but i suspect at least 2 bar boost pressure for the 535d. Or logicly maybe the boost pressure would be less in the 535d because of the TT setup.?!? or m i wrong?
Anyway more info is greatly appreciated...
"This is only "nice to know" information and will be used in conversations in local bar, with other petrol heads! "
Exactly
My Ride: 535d, orient blue, Dakota beige, Dynamic Drive, Xenon, Nav Prof, Bluetooth, comfort seats, PDC, curve lights, 135M wheels
Bernd
.... in conversations in local bar, with other petrol heads!
Skaffa
Skaffa
Originally Posted by moema535d' date='Sep 25 2005, 02:22 PM
[quote name='skaffa' date='Sep 25 2005, 11:18 AM'].... in conversations in local bar, with other petrol heads!
Skaffa
Skaffa
[snapback]174791[/snapback]
[/quote]Aaaand?
He has a diesel, and he was talking about a possible conversation in a bar with some petrolheads!
My Ride: -04 530D
Originally Posted by moema535d' date='Sep 25 2005, 10:16 PM
[quote name='skaffa' date='Sep 25 2005, 11:18 AM']I have not found conclusive information about boost pressures in BMW diesels from net. Some say that 535d have 2,85bar boost, but that sounds high, comparing information that 530d should have about 1,8 bar.
Bernd
[snapback]174788[/snapback]
[/quote]I read this same info from somewhere else. Do anyone know reason why boost pressure has given as absolute pressure? Can it be because inlet manifold can go to "negative" if gauge pressure is used?
E60Speed You have been good source of info, can You help in this?
Skaffa
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
