BMW: user error post!
Old Apr 27, 2005 | 03:14 PM
amigo525's Avatar
Here it goes:
Some time ago, some one posted a msg about better heat distrubution thru the I/D. Oh well, I went ahaed and did the same.
About two weeks ago, it was very hot in new york. So I said, hey let me test my A/C. Oh boy, my A/c was blowing heat! I was puzzled and said "wow only a year and already giving me a/c problem." --Guess I need to call the dealer.
The next day I started to monk around with my I/D and saw my bug.
Oh well..! good thing i did not take my car for service if not, I would look like a fool
Old Apr 27, 2005 | 03:36 PM
juan2mini's Avatar
amigo525
What was wrong with the I/D settings that caused your ac to blow hot air? Many thanks
Old Apr 27, 2005 | 03:42 PM
Hormazd's Avatar
Originally Posted by juan2mini' date='Apr 27 2005, 03:36 PM
amigo525
[snapback]120980[/snapback]
I am guessing that he had the setting below (4) set to blowing hot air.
Attached Thumbnails BMW:  user error post!-2004manual_5series_page_095_image_0003.jpg
555's Avatar
555
My Ride: E60
I'm guessing he had that one setting in Vent settings set to "orange". Ya know, that one setting sort of in the middle that you set to blue (cool) or orange (warm).
Originally Posted by juan2mini' date='Apr 27 2005, 05:36 PM
amigo525
Old Apr 27, 2005 | 04:05 PM
juan2mini's Avatar
Hormazd & 555:
Thanks for the insight, much appreciated. Does that mean I should be changing my I/D "temp" setting for summer or winter conditions? If I "check" the auto box at the bottom, will that override the other settings? I have had my car since 11-03, maybe I should read the manual - again. Thanks again for your help.
Old Apr 27, 2005 | 07:43 PM
Hormazd's Avatar
Originally Posted by juan2mini' date='Apr 27 2005, 04:05 PM
Hormazd & 555:
Thanks for the insight, much appreciated. Does that mean I should be changing my I/D "temp" setting for summer or winter conditions? If I? "check" the auto box at the bottom, will that override the other settings? I have had my car since 11-03, maybe I should read the manual - again. Thanks again for your help.
[snapback]121006[/snapback]
Later software versions have removed the auto check box. Since CIP 12 I think. CIP16 even removes the icon from the bottom of the I-Drive.
To answer your question, selecting Auto does not effect this setting. I have it set at neutral (one white bar). The system is designed to always blow cooler air at the top. So if you select a higher temperature, expect to see results from the bottom of the cabin. Its about overall comfort and not the temp of the air coming from the vents. The manual suggeests you direct the upper vents past you and not on you. I tend to fiddle with that setting more than I should because I like air on my face.
Skaper
21
Aug 30, 2017 06:54 PM
sebash
Jul 30, 2015 12:40 PM
Bank$hot530
Jul 18, 2015 02:25 PM
ROCKITMAN
Jul 13, 2015 02:16 AM
Bank$hot530
Jul 12, 2015 04:36 PM
