bmw recall
Old 06-30-2005, 01:13 AM
  #21
hedikmn's Avatar
My Ride: 525d black on black sport seats, shadow line rear and side sunshades, sport wheel, brushed aluminium interior trim, sunroof, ......
Originally Posted by sango' date='Jun 29 2005, 08:06 PM
how can we know that? exhaust were replaced ???
i also have recall and my dealer were replaced that exhaust but? ? how can i know if they changed it?
[snapback]144257[/snapback]
interesting point but i guess u just have to trust ur dealer
hk
Old 06-30-2005, 06:01 AM
  #22
seakat's Avatar
Originally Posted by ANDY' date='May 12 2005, 09:07 PM
Also steering occaisionally makes a loud grinding noise when turning. Yet again has any one else had this problem.? ? ? ? ? ? ? ? ? ? ?
On another point does anybody know if in dash cd player operates as an mp3 player. I have no NAV. Is this a software issue or do you have to have NAV for mp3 to work..
[snapback]127708[/snapback]
I had the same problem, and dealer fixed it replacing the whole steering system. Quite expensive (for BMW), but they said it's a known problem. Everything ok since then.
AFAIK you must have pro radio and business NAV at the moment to get mp3. Pro NAV owners are still waiting
Old 09-13-2005, 06:11 AM
  #23
golfnut's Avatar
My Ride: Oxford Green E60 530D with tuning box and all the toys!
Just heard of another case of an exhaust manifold failing in a 2004 530D and it caused no end of turbo problems etc. The model in question was fitted with the modified (post recall) part. The recall was for a specific early 2004 build - anyone else had trouble with this issue with or without a recall notice?
Old 09-13-2005, 08:56 AM
  #24
sango's Avatar
[snapback]169985[/snapback]
you mean that issue is about turbo problems or???my dealer replaced exhaust manifold in may i think...now again problems??
Old 09-13-2005, 07:25 PM
  #25
ridleyr's Avatar
My Ride: 2004 545i, 19" Alpinas, Lowered, sports suspension, Tints, Active lights, Adaptive steering, Electric Roof, Sat Nav Business, ext light package, Steptronic, Silver Grey, Black Leather Interior, White lens Past cars Bmw 320i(83),Bmw 325i sport(86),Bmw 318iS(93),Bmw 328 Ci(98),Porshce 968 Club Sport(93), Bmw 325i Cab(99), Bmw 530i Sport(01), Bmw 545i SE(04) I havent mentioned some of my earlier cars i.e. Austin Allegro, Escort Mk2
Had the same problem with steering noise, dealer cured by total strip down?unfortunatly the steering wheel was out of alignment, complained to dealer and asked to take it back solved the alignment problem in 1Hr, stated that some sensor had been incorrectly set, now both the noise and the steering wheel alignment perfect, I would take it back and tell him to get it positioned correctly!
Old 09-14-2005, 01:38 AM
  #26
golfnut's Avatar
Originally Posted by sango' date='Sep 13 2005, 05:56 PM
[quote name='golfnut' date='Sep 13 2005, 03:11 PM']Just heard of another case of an exhaust manifold failing in a 2004 530D and it caused no end of turbo problems etc. The model in question was fitted with the modified (post recall) part. The recall was for a specific early 2004 build - anyone else had trouble with this issue with or without a recall notice?
[snapback]170045[/snapback]
[/quote]
The manifold failed and threw debris through the turbo. The turbo then failed and required replacement along with the cat and particle filter. Obviously not a common problem then, judging from the response!
Old 09-14-2005, 04:03 AM
  #27
browellm's Avatar
Funnily enough, I have just called BMW out for a failed turbo. I'll let you know the outcome.
Old 09-14-2005, 04:39 AM
  #28
sango's Avatar
Originally Posted by browellm' date='Sep 14 2005, 01:03 PM
Funnily enough, I have just called BMW out for a failed turbo.? I'll let you know the outcome.
[snapback]170370[/snapback]
we waiting your info.....
Old 09-14-2005, 05:52 AM
  #29
browellm's Avatar
Originally Posted by sango' date='Sep 14 2005, 12:39 PM
[quote name='browellm' date='Sep 14 2005, 01:03 PM']Funnily enough, I have just called BMW out for a failed turbo.? I'll let you know the outcome.
[snapback]170380[/snapback]
[/quote]
It was carted off to the dealer this afternoon. I guess I won't hear for a couple of days.
Old 09-16-2005, 05:53 AM
  #30
browellm's Avatar
Got the car back within 24 hours, dealer had replaced the turbo assembly.
Didn't get any information as to why it failed, car has 27,400 miles on it.
Obviously I'm pleased the car has come back so quickly, on the other hand it's worrying that the part was on the shelf - perhaps it's an all too common occurence.
I imagine it's a high cost repair out of warranty
Quick Reply: bmw recall
