BMW and ethanol
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
Hi,
I'm posting this here because it has to do with gasoline and BMW cars in general and not just E90 series.
I have a slight issue with my 2008 E93 where I detect a little shaking in the morning until it warms up and then it's nothing but smooth engine until the next morning.
The dealer went as far as testing the gasoline in the tank and they detrmined that I use 15% ethanol gas and they stated that their cars are warranted only up to 10% ethanol gas.
Now, I use a top-tier gas (Shell) and I only use premium and I had no idea about this 10% vs. 15%. Digging in a little deeper, I found out that the EPA mandates that cars MY2007 and newer must accept 15% ethanol.
Does anybody know if this also applies to BMW or if they were given an exemption? What would you do at this point? For the record, I'm going to start looking for 10% ethanol, but what am I supposed to do when the government mandates that all gas stations sell 15% ethanol gas?
What top-tier gas do you use in Massachusetts with 10% ethanol?
Thanks for listening.
There's not much you can do about it.
Here in NY, gas stations have stickers that state, "contains 10% ethanol", but I've had my dealership say they've pulled more than that % out of my tank as well. The problem, as I understand it, is that the ethanol is blended in/mixed/whatever at the point of delivery, so you would need to rely on the competence of the delivery chain to measure it properly. Yeah, okay.
I have found one place locally here that sells NO ethanol gas, and let me tell you, the line is around the corner at this place. According to them, gasoline is stored at the airport, but because of the corrosive properties of ethanol, they can't blend the ethanol in until it hits the delivery truck. (Makes you wonder, huh) So all the gas is stored without ethanol. They just order it without the ethanol, and pay more for it. It's made a world of difference in my car's performance. See if you can find a place around you. You'll know which ones... they are usually very passionate about no ethanol, and they advertise as such.
You will definitely see a performance benefit by eliminating ethanol, as it has about 50% less combustion energy than gasoline.
My Ride: E60 550i, Ducati 748
You can go on www.pure-gas.org and they have lists for every state that tells you where there are gas stations that sell ethanol-free gas.
My Ride: 2008 535i:
1992 Camaro RS:
In GA gas stations are allowed to mix up to 15%. I think the mixture varies throughout the year because during the colder months I notice slight hesitation during startup but in the warmer months the car starts up fine.
The ethanol content is "supposed" to be constant throughout the year. Winter-blend fuels have a higher vapor pressure (ability of the gasoline to vaporize which makes it easier to ignite), in part, to combat the cold weather hard starting issue. Typically butane is added at higher levels to achieve this effect. Vapor pressure increases as temperature increases, so whenever it is warmer it will be easier to combust the fuel. Summer-blend fuels have a lower vapor pressure to avoid excessive vaporization which leads to air pollution. The summer-fuel season starts around May-June timeframe (now!) and the winter-fuel season starts in September. This is all mandated by the US EPA. Also, in the US, there are many different fuel blends that vary by region.
Engine: N54
ethanol isn't always a performance killer and it isn't near 50% less energy (more like 30%) but it is cheaper so the less miles/gallon isn't as bad as it may seem.
Many guys seek out E85 for the performance benefits of it (85% ethanol) which include a slower burn, higher octane than 93 gas, cooler combustion. These benefits are notable in power adder applications like our 335/535 turbo charged, high compression engines as long as you have a tune that can take advantage of it.
OP - Stick with top tier stations like Shell, Marathon, Phillips 66 for a few tanks and see if you notice a difference. Also, search on topics for intake valve cleaning - our cars can get pretty bad due to the direct injection and bad idle is a common issue. Whatever they are telling you about ethanol%, etc is just detracting from whatever the real issue is.
Also I meant to say that gasoline is roughly 50% more energy dense than ethanol. Based on the LHV (Lower heat of combustion):
*LHV (ethanol) = 76,330 BTU/gal
*LHV (gasoline) = 116,090 BTU/gal
% Difference = (116,090-76,330)/76,330 = 52.1%
This is not a trivial amount and results in the very real fuel efficiency differences.
* Reference: American Petroleum Institute (API), Alcohols and Ethers, Publication No. 4261, 3rd ed.
My Ride: 2004 545i 6 speed, Silver Gray A08, Gray leather
Mods: Hard-Wired Passport 9500ix LIVE , K&N Air + RPi Scoop, Mtech V2.1 AE, ACS pedals+Ebrake, flip up front plate, OEM 172's, Custom M Kit, M3 shift knob, Eisemann Race Exhaust
2005 X5 3.0 (the nightmare)
1998 528i SOLD @ 173K
Im running a 40% mix of e85 and 60% 93. My 335i loves it
![](https://5series.net/forums/public/style_emoticons/default/twoup.gif)
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
I just checked www.pure-gas.org and it seems as though there are only 5 gas stations in the state of California that have non-ethanol infused gas. Wow!! Very interesting topic. Thanks for the input.
