BMW E60 LCI sunroof displays anti-trap message
My Ride: BMW 530D M Sport LCI
So after I washed my car and let it dry for a little while I took it for a drive and parked at a local shop. When I got back in and turned it on a message saying sunroof anti-trap function (or something similar). I tried to operate the sunroof and it worked fine opening thou wouldnt close back up again. I checked around and inside the the sunroof but couldn't see anything trapped in there. I did the restart procedure by holding the button pressed for 15 secs and close back up again.
Since it close up back its obvious nothing in the mechanism is broken otherwise it wouldnt be able to close or open. I checked and there wasnt anything trapped in it either.
Im not too sure how to fix this, could it be maybe something with the software :S
its a BMW E60 LCI 530D M-Sport if that helps.
Anyone got a clue why could of gone wrong?? Any help would be much appreciated.
Thanks Guys
Thanks Guys
Is the sunroof open now? You can close it manually if you have the tool. Looks like this: BMW E53 X5 M54 3.0L Interior Sunroof - 54137199324 - Sunroof Tool - ES#157645
Have you seen this video?
SFx550i
04-14-2015 05:00 PM
BYS2
03-24-2015 03:13 AM
