BMW e60 530i CAN malfunction
Old May 18, 2022 | 07:03 AM
Rolplay's Avatar
My Ride: BMW 530i PreLCi
Default BMW e60 530i CAN malfunction
Hi! Since i buy the car, i have a problem with can modules, but today the car went to limp mode, so i want to figure it out what's wrong.
CAR: 2003 BMW e60 530i - M54B30
My error codes after limp mode:
28DD - DME: Air mass system - Existent
28AE - DME: Torque limitation: Monitoring - Existent
5F77 - DSC: Engine management: Interface - Existent
D904 - CAS: K-CAN line fault - Existent
D907 - CAS: K-CAN communication fault - Not Existent
E584 - KBM: K-CAN line fault - Existent
E587 - KBM: K-CAN communication fault - Not Existent
9C77 - IHKA: Auxiliary-water pump - Existent
E244 - SZM: K-CAN line fault - Existent
E2C4 - CON: K-CAN line fault - Existent
9E5C - SMFA: Rapid heating area: cushion - Not Existent
E444 - SMFA: K-CAN line fault - Not Existent
E484 - SMBF: K-CAN line fault - Not Existent
E184 - CD/ M-ASK/CCC/RAD2/CHAMP-GW: K-CAN line fault - Not Existent
FFF2 - MOSTSYS: MOST ring break - Unknown
Codes after deleting:
E504 - LM: K-CAN line fault - Existent
I already tried:
- Cleaning ICV, Throttle Body. Re do and cleaning plug connections. Adapt Throttle Body.
- Replaced SGM, LM to LM2, DME, CAS
- Redo plugs in SMFA,SMBF, SZM, M-ASK
- Replaced MPM
- I tried to disconnect SMFA,SMBF and check, but nothing changed.
Old May 18, 2022 | 09:38 AM
Rolplay's Avatar
The question is: What can i try? I think probably the KBM is the problem, but everything works fine, so i don't know where i need to start
Old Dec 15, 2022 | 01:26 PM
jrdaguio's Avatar
My Ride: Bmw e46 @ e60
Default Same issue
Did you ever figure this out? i have the same codes and same issue
Old Dec 16, 2022 | 07:11 AM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2019 i3s
Engine: N54
I had this issue pop up the other day as well. Fortunately for me it ended up just being the drivers seat module. I figured I would just start unplugging modules one at a time and rescanning for codes and hope they would go away at some point. If that doesn't do it, probably a wire on the bus somewhere that is broken. When I unplugged my driver seat module the errors went away and returned when I reconnected. Fortunately I found a used module on Ebay for $10 that's on its way. Seat modules are the quickest thing to disconnect, also some of the modules in the trunk.
Old Dec 18, 2022 | 11:41 AM
jrdaguio's Avatar
Which did u unplug the yellow one? under the seat?
swimrr
Feb 1, 2024 02:00 PM
Dean Greatrex
FO7 Gran Turismo Discussion
May 11, 2021 12:39 PM
NFJ79
Sep 4, 2019 06:02 AM
Aboom
Jan 11, 2019 09:11 PM
monnot66
Nov 14, 2008 06:58 AM
