Bmw e60 525d fuel problem
Old Apr 18, 2021 | 08:57 AM
Mlinka's Avatar
Probation Members
My Ride: E61 525D
Default Mr.
Originally Posted by Alanw1992
Hi new to the page need some help
Got a 525d and fitted a new fuel pump in tank and everything going was great in till used all the fuel from right side and all went to left side can't Figure it out had about 3 pumps now do I have to reprogramming something or reset engine management and how does.it lift fuel from left side to right thanks
Good day, Im having the same problem like you with my E61 525d M57 engine. Did you manage to solve the problem?
Thank you very much.
Old Apr 21, 2021 | 03:51 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
You may want to check to make sure all the hoses are connected. It's only pulling from one side
Old Dec 16, 2021 | 05:19 AM
Dixon3880's Avatar
Probation Members
My Ride: Stage 3 e60 525d
Default 525d fueling
Did this issue ever get sorted please, I'm currently having the exact same issue
Old May 31, 2025 | 01:15 PM
CZPet's Avatar
Default 535D the same problem....
Hi guys, I know this is a very old topic, but it's still very relevant for someone. I think I have a completely identical problem. Both units are brand new from BOSCH. I've taken them out several times, checked the connections, etc. I don't know what to do next. I'm starting to suspect that the problem may be elsewhere. Somewhere around the filter on the inlet, a blocked return line, etc. Because pumping from left to right drives a reverse flow of diesel from the return line. In the service menu, you can observe the movement of fuel, which I've been doing for the last few days. The last time it happened to me that the car stalled and wouldn't start, with about 12-13 liters of fuel remaining in the left half and the right half empty. After refueling, it keeps going. Depending on the fuel level in the hidden menu, but also in the diagnostics, the fuel sometimes moves from right to left, after turning off the engine and starting it again it starts moving in the correct direction from left to right. Has anyone solved this???
Old Jun 1, 2025 | 11:11 AM
CZPet's Avatar
Does nobody really know anything?
Old Jun 1, 2025 | 11:12 AM
CZPet's Avatar
Old Jun 1, 2025 | 02:55 PM
donpb's Avatar
My Ride: '06 530i N52
It could be due to a lot of things. Use a BMW-specific code reader instead of the hidden menu.
Old Jun 1, 2025 | 03:07 PM
CZPet's Avatar
Thanks for the response, of course I do that. There are no errors stored anywhere, only error 4587 in the ECM - fuel filter heating.
I only use the hidden menu in the cluster to monitor the status of the left and right halves, these values ​​are identical in the diagnostics.
Old Jun 1, 2025 | 03:18 PM
donpb's Avatar
You could have a clog in the fuel line. What's your fuel pressure reading? How long have you had this issue for?
