bmw e60 520d smells like burn oil in the cabin
bmw e60 520d smells like burn oil in the cabin when the car is stable. The car doent have smoke the from the engine or the EXHAUST. exhaust system check,(no leaks).check the pdf pressure(ok) fumes
What’s wrong? I need help?
I have seen this on a BMW in the past where the head gasket needed to be replaced as it was leaking a bit of oil. That oil was dripping on the hot engine parts, then the smell of burning oil was being sucked in through the cabin air filters.
Could be one of many things, but easy enough to check.
Model Year: 2015
Engine: N55
If it is only obvious when the car is stationary then it may be a cracked exhaust manifold.
It is not easy to spot, they crack right where the manifold joins the engine, mine was missed twice by dealers.
turbogate
04-11-2015 05:02 PM
thesalboy
04-08-2015 09:13 AM
BYS2
03-24-2015 03:13 AM
