BMW Dynamic Drive Malfunction
Hello I own a 2005 BMW 525i. One day while driving on the Idrive system a message popped up about a dynamic drive malfunction. Also an image on the on the drivers cluster showed a car rocking to one side with an exclamation point. I have already checked the power steering fluid. Any suggestions?
Some reported overfill or low power steering fluid could trigger it. Mine did that several times over a few years - a message warning for a day or two and then it went away and returned 6 months later or went away, etc. Finally, it came on and never went off. A sensor went bad and the dynamic drive unit had to be replace. It could have a leak somewhere as well.
Dynamic Valve block
Any ideas on a dynamic valve block check engine light. Looks like a sideways car I'm not sure what the part number is nor is my Indie from there you with it but I know it's the part behind the right front passenger side wheel. Used a go for pretty cheap new there over a thousand bucks any ideas
