bmw dealer told me
My Ride: 525i 07
thats what he said and also if i got any after market rims suspesnion goes out of warranty and also the mtech kit should come from bmw otherwise they would not install it there as the car will be out of warranty also, when i asked them about installing koni's suspension they said also u will get out of warranty, when i asked them about m5 grills they said u will need m5 feneders??? asked them about getting the grill and install it on my orginal feneders they said they have never done this before i dont know what to do??
![Nono](https://5series.net/forums/images/smilies/imported/nono.gif)
My Ride: 525i 07
ah i forgot even when i asked them about quad diffuser for 550 with two opening they said 550 comes with one opening in the diffuser like 525 is that correct i need part numbers ?? i feel like :thumbsdown:
My Ride: 2009 DINAN 135 convertible
They are correct about the 550 diffuser only having one outlet, as you can only get quads w/M5. If you get M5 diffuser, then it will have quad outlets.
As for other stuff, most dealers apparently know nothing about the Magnusson-Moss Warranty act, but basically, they cannot void your warranty unless the mod you did was responsible for the failure that you want covered by warranty. If you are not in the U.S., then I assume it would be a different story.
My Ride: 525i 07
well i got it about the diffuser but i have seen many mtech kit with quad exhaust i think, and about getting used mtech from a friend they said no u it will void my warrant ?? how come, they said every thing should be with bmw bills to insure that they are orginal? and the m166 wheels said it doesnt fit on my 525?
What? Inspect? They must be on crack... in that case you are stuck... either keep it stock or spend your money on the dealer.
What year is your car? If I'm w/ your dealer they'll ban me all the way considering what I've done
