BMW 535xi AWD, DSC, ABS, and EMERG EBV
My Ride: 2008 BMW 535 xi
2008, 535xi, in Toronto, Canada ( just passed a very cold winter ) my wife drives it 8 miles one way to work. parked in the garage. had one weak battery replaced 3 years ago under warranty, changed the brake last year.
The above msg has shown up for days. Today I tried to charge the battery, reset the msg by turning the wheel to left end then right most. test-drove for 1 mile and the msg showed up again. The battery condition should be better than last time. Last time, the battery couldn't hold date and time settings and finally couldn't start the car.
Anyone can give me some advice?
My Ride: 2008 528xi (Silver)
Need a new battery! If a battery wont hold charge, it will only get worse over time. You can charge it back up, but it will be temporary and the battery wont hold as much amps. Once battery is low and sits low for a while, usually the battery doesn't survive. Unless properly reconditioned. Id suggest a new battery, get it from dealer and code(register) locally.
TroyE60
05-30-2019 05:01 PM
