BMW 530D Auto Transmission Failure
Hi guys, unfortunatelly something bad happend![Angry](https://5series.net/forums/images/smilies/imported/angry.gif)
The car was running fine, everything was okay. I've stopped for 10-15 minutes and after I started the car there were fault message for the ABS, Active Steering, DSC, Dynamic Drive - all these lights came up on the instrument cluster, along with the TRANSMISSION FAILURE.
I'm not sure if the problem is in the transmission itself, or somewhere in the CAN communication because as I said all the above warrnings were on the cluster. Also the spedometer didn't work, only the RPM meter, no iDrive, no Radio, no power windows, no air conditioning - nothing with the car started, but when the ignition is on - everything works.
I've removed the negative connector of the battery and after a few minutes I reconnected it and everything was okay. I'll check for specific error messages with INPA and I'll write them down. In the mean while can you throw some suggestions? Is it the Torque Converter?
My Ride: 04 545i - Titanium Silver/Black, Sport pkg, Comfort Seats w/ Lumbar, Premium Sound, power rear sunshade, Adaptive Xenon Headlights, Steptronic, Park Distance Control, Fold down rear seats w/ski bag, Aux jack, 6-disk changer, puddle lamps...
Engine: Custom Remus cat-back exhaust w/chrome square tips, K&N Air Filter, Charcoal Filter Removed, Sprint Booster :-), 50/50 mix of 91+100 Octane, EuroRev ECU Remap (coming soon lol), Dinan High-Flow Throttle Body (coming soon...maybe lol)
Interior: Portable Sirius Stilletto 100 w/car kit, Garmin Nuvi 680 mounted below rear-view mirror, LCI-style I-drive knob, Dark Poplar Center Dashboard Trim.
Exterior: E60 forum clings, 5% rear tint, ACS roof spoiler (painted black for distinct look against limo tint), ACS trunk spoiler, ACS add-on front spoiler and rear apron (awaiting installation), "18 Black Staggered BeBeS Style OER (emergency replacement for cracked sport 124 rims), black kidney grill, white accessory lighting (including license and trunk lamps), Angel-eye upgrade, AIB xenon-matched fog lamps, AIB V3's on order, red rear reflectors
+1. Yup. Do a search. When your dash lights up like a rougue xmas tree, chances are a voltage issue is the cause. Chances are high it is a battery voltage problem, possibly caused by the wonderful intermittent actions of a failing alternator (been there, done that). If it is the ole Alty, at some point you'll be motoring along nicely. You'll notice your iDrive may start turning on and off. Audio may get sporadic. Then you'll start getting the dreaded "Bling" warnings (some if so equipped): Abs, Active Steering, Ars, dynamic drive, and, usually finally, transmission warning and gear lockup. Keep driving and things go dark as the car keeps systematically shutting down electrical systems so you can keep rolling. Eventually, the party comes to an end when there simply isn't enough juice to keep the plug voltages, fuel pump, and ecu powered. Shutting down, waiting 10 minutes, then restarting usually gave me enough reserve voltage for a start attempt, at which point the alternator usually decided to awaken and, well, alternate lol. There is also a 20 buck charge control relay in the fuse panel above the battery. If it is indeed the Alternator, its wise to replace the relay as well. A bad battery will give you xmas trees before starting, but usually smooth sailing when running as the alternator struggles to keep up enough voltage to power the car and supply charge power to the batt. Good luck!
Thank you very much guys! First I was confused, way the trani failure and all other things, then I decided that there is something with the CAN communication.
The interesting thing was that with ignition ON everything was fine, but immediately after starting the car the idrive, sound and etc were all gone and the transmission faliure was on the cluster and I think the locked gear was 3th.
I'll start monitoring the voltage in the car, hopefully if there is a problem it will be in the alternator not in the transmission.
When I read the errors I'll poste them. Fingers crossed
UPDATE:
You guys were both right - there was a high voltage - 16-17 volts.
Most of the modules accross the car recorded fault codes for the voltage problem. Now the cars drives perfect, I'm monitoring the voltaga in the hidden menus and it is 14v, 14.2v.
I've found a different code in the GEARBOX IM (5118 InfoCounter1 - EGS-Reset) and I have no idea what it is?
The next step will be to buy a new relay (the one located behind the alternator) and replace it. As I'm familiar this should solve the high voltage problem, right?
Thank you for your fast reaction. I'll keep updating the thread with eventual problems and how I resolved them.
Here are some of the fault codes I've already deleted.
Code:
ENGINE: 4660 4660 Supply voltage Error counter: 5 Logistic counter: 40 1. Umweltsatz Mileage 177792 km mean engine speed 965.38 rpm coolant temperature 89.28 deg C max rail pressure of the recent 10ms 370.22 bar injection mass index value without mass balance control 16.15 mg/cyc intaken air mass per cylinder 422.21 mg/Hub value of boost pressure 945.23 hPa linearised APP1 8.66 % Battery Voltage 17433.11 mV Vehicle speed 0.00 km/h atmosphaere pressure 945.23 hPa 2. Umweltsatz Mileage 177792 km mean engine speed 992.97 rpm coolant temperature 92.29 deg C max rail pressure of the recent 10ms 433.24 bar injection mass index value without mass balance control 18.12 mg/cyc intaken air mass per cylinder 453.71 mg/Hub value of boost pressure 984.61 hPa linearised APP1 11.02 % Battery Voltage 17433.11 mV Vehicle speed 0.00 km/h atmosphaere pressure 945.23 hPa Versorgungsspannung DDE ueberschritten Test conditions fulfilled Error not occurred yet Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 46 60 01 06 00 00 05 28 56 D0 23 8B 2F 29 43 60 0B 6B 00 60 56 D0 24 8E 37 2E 48 64 0E 6B 00 60 ------------------------------------------------------------- 4545 4545 Powermanagement Bordnet Error counter: 3 Logistic counter: 40 1. Umweltsatz Mileage 177792 km mean engine speed 965.38 rpm coolant temperature 88.27 deg C max rail pressure of the recent 10ms 370.22 bar injection mass index value without mass balance control 14.18 mg/cyc intaken air mass per cylinder 447.41 mg/Hub value of boost pressure 984.61 hPa linearised APP1 8.66 % Battery Voltage 7820.46 mV Vehicle speed 2.96 km/h atmosphaere pressure 945.23 hPa 2. Umweltsatz Mileage 177792 km mean engine speed 0.00 rpm coolant temperature 94.30 deg C max rail pressure of the recent 10ms 0.00 bar injection mass index value without mass balance control 0.00 mg/cyc intaken air mass per cylinder 0.00 mg/Hub value of boost pressure 955.07 hPa linearised APP1 0.00 % Battery Voltage 12545.33 mV Vehicle speed 0.00 km/h atmosphaere pressure 945.23 hPa Ueberspannung Test conditions fulfilled Error present now and already stored Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 45 45 61 06 00 00 03 28 56 D0 23 8A 2F 24 47 64 0B 30 03 60 56 D0 00 90 00 00 00 61 00 4D 00 60 ------------------------------------------------------------- 3F05 3F05 (0701) MIL OFF P0701 Transmission Control System Range/Performance Error counter: 1 Logistic counter: 40 Mileage 177792 km mean engine speed 661.98 rpm coolant temperature 90.28 deg C max rail pressure of the recent 10ms 299.33 bar injection mass index value without mass balance control 10.63 mg/cyc intaken air mass per cylinder 415.91 mg/Hub value of boost pressure 945.23 hPa linearised APP1 0.00 % Battery Voltage 16781.41 mV Vehicle speed 0.00 km/h atmosphaere pressure 945.23 hPa Getriebeanforderung Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 3F 05 21 02 07 01 01 28 56 D0 18 8C 26 1B 42 60 00 67 00 60 ============================================================= GEARBOX EM: 5014 U_Batt, Gearbox P1891 System Voltage High Input Error counter: 3 Logistic counter: 40 1. Umweltsatz Mileage 177784 km Engine speed 640.00 rpm Battery Voltage 16.32 Volt supply voltage DR/MV 16.32 Volt Turbine speed (rpm) 224.00 rpm 2. Umweltsatz Mileage 177784 km Engine speed 672.00 rpm Battery Voltage 16.72 Volt supply voltage DR/MV 16.64 Volt Turbine speed (rpm) 0.00 rpm 3. Umweltsatz Mileage 177784 km Engine speed 672.00 rpm Battery Voltage 17.04 Volt supply voltage DR/MV 16.96 Volt Turbine speed (rpm) 448.00 rpm U_Batt bigger than nominal Value Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up ===================================== GEARBOX IM: 5118 InfoCounter1 - EGS-Reset Error counter: 4 1. Umweltsatz Mileage 175280 km Gearbox Oil Temperature -2.00 degrees C Battery Voltage 6.88 Volt substrate temperature -3.00 degrees C time after reset/ignition OFF-ON 60.00 ms 2. Umweltsatz Mileage 175280 km Gearbox Oil Temperature -2.00 degrees C Battery Voltage 7.04 Volt substrate temperature -4.00 degrees C time after reset/ignition OFF-ON 60.00 ms 3. Umweltsatz Mileage 176120 km Gearbox Oil Temperature 12.00 degrees C Battery Voltage 12.16 Volt substrate temperature 10.00 degrees C time after reset/ignition OFF-ON 0.00 ms EGS-Reset Test conditions not yet fulfilled Error present now and already stored Error would not cause a warning lamp to light up Error code: 51 18 78 04 55 96 26 56 25 02 55 96 26 58 24 02 55 FF 34 98 32 00 ============================================================= DSC: 5DD0 UZ-Error: Ueberspannung (Voltage too high). Error counter: 1 Logistic counter: 34 Mileage 177792 km Fahrzeuggeschwindigkeit 3.31 km/h ACB 0.00 0/1 DBC 0.00 0/1 ECD 0.00 0/1 HDC (nur 4x4) 1.00 0/1 DSC 0.00 0/1 ABS 0.00 0/1 BLS 1.00 0/1 ASC 0.00 0/1 No matching error symptom Test conditions fulfilled Error not present now, but already stored Error would cause a warning lamp to light up Error code: 5D D0 A0 01 22 56 D0 00 35 48 ------------------------------------------------------------- 5EB4 yaw rate sensor: NO7: supply voltage too high Error counter: 1 Logistic counter: 34 Mileage 177792 km Fahrzeuggeschwindigkeit 0.00 km/h ACB 0.00 0/1 DBC 0.00 0/1 ECD 0.00 0/1 HDC (nur 4x4) 1.00 0/1 DSC 0.00 0/1 ABS 0.00 0/1 BLS 1.00 0/1 ASC 0.00 0/1 No matching error symptom Test conditions fulfilled Error not present now, but already stored Error would cause a warning lamp to light up Error code: 5E B4 A0 01 22 56 D0 00 00 48 ------------------------------------------------------------- 5F6D yaw rate sensor: DRS2: NO7 supply voltage too high Error counter: 1 Logistic counter: 34 Mileage 177792 km Fahrzeuggeschwindigkeit 0.00 km/h ACB 0.00 0/1 DBC 0.00 0/1 ECD 0.00 0/1 HDC (nur 4x4) 1.00 0/1 DSC 0.00 0/1 ABS 0.00 0/1 BLS 1.00 0/1 ASC 0.00 0/1 No matching error symptom Test conditions fulfilled Error not present now, but already stored Error would cause a warning lamp to light up Error code: 5F 6D A0 01 22 56 D0 00 00 48 =============================================================
Sounds like your voltage regulator is acting up. Voltage spikes that high can fry your electronics! The regulator is integrated into the alternator. It may be prudent to simply replace the alternator with a new/factory spec refurb unit.
It is very wierd, how it wasn't working properly and after a reset everything is okay. I'm going to replace it asap, but at the dealer it is not available and I need to order it.
The error above your EGS(tranny ECU) reset its hearbeat timer, not a problem. But monitor the voltage and see if it's actually a problem. None of us knew that when buying an E65, E60,E90, E80 chassis family that the vehicles come gremlins
Yesterday after the reset (with unpluging the negative connector) the charge was 14-14.2 volts. This morning I was getting high 14 and some times 15, 15.1 volts. The thing I notice that it not stable it jumps from 13 to 15, but mostly it is around 14.6-14.8v. So I'm guessing that the voltage regulator is having some problems. Probably the charge should be stable 14 or mid 14.
I was thinking for another issue with the sensor which measures the voltage, but after the morning drive I'm 99% it is the voltage regulator.
