BMW 530 i 2005 jerking
I have the following problem: From time to time (short jerks) when accelerating from 1500 -2000 rpm. Only with a warm engine.
Both in the D and on manually (I thought at first that the automatic transmission hesitated in D) I once had a broken coil (jerking at high rpm and a message misfire) Up to now I have seen no error message. Also via the OBD can find no message. I already replaced the camshaft sensors, no change. The MAF already replaced without result. I've checked several readings: Short term trim, bank 1: ranges from +6 to -10, -10 when accelerating, bank 2 idem. Long term trim, banking one: always in the minus range of - 6 to -3.5, bank two comparable. Apparently the mixture without correction isw to rich (excessive fuel pressure ??) I see on various forums that deviations from the Long term trim up to 20% is not really a problem). While stuttering (takes only few seconds) I do not see any weird values. what could be the cause |
problem solved, after changing the spark plugs.
Some times thye solution is easy. |
