BMW 525d problem or not a problem?!
Hi all,
yesterday I was cheking the oil and coolant level then I opened the oil cap and WTF this sound appears! Check the video! Does anyone knows what is that? Someone tells it normal, but I want to be sure before I go to the garage for inspection. Another problem is, I don't know when this starts to happen but my iDrive don't save any settings I made in it, except clock, date, and settings for lock, light and that stuff. Radio stations and language does reset when I get from car like for 5 - 10 mins. And it's reseting the hidden menu on the dashboard. I get the lock off, and when I am off the car for like 5-10 mins it reset and I need to do the process always! It very annoys! Did someone had this problem? |
For the issue of various components resetting, get a new battery and install.
About the engine noise, are you saying that noise comes and goes away OR that noise is there all the time? |
Do I need to do some programming after I install the new battery?
That noise is always there. I tried on cold and warm engine, the noise is the same.. |
It is a good idea to get the battery registered; most of the indy shops can register the battery.
About the engine noise, that is definitely not normal. Change the battery and get that noise diagnosed. |
Thanks, I will do that.
Hmm, I will go to the garage next week. And see what they tell. If anyone have this noise or dont have I will be thankfull if they say something about it. |
Originally Posted by razor_061
(Post 1495157)
Hi all,
yesterday I was cheking the oil and coolant level then I opened the oil cap and WTF this sound appears! Check the video! BMW 525D engine sound noise - YouTube Does anyone knows what is that? Someone tells it normal, but I want to be sure before I go to the garage for inspection. Another problem is, I don't know when this starts to happen but my iDrive don't save any settings I made in it, except clock, date, and settings for lock, light and that stuff. Radio stations and language does reset when I get from car like for 5 - 10 mins. And it's reseting the hidden menu on the dashboard. I get the lock off, and when I am off the car for like 5-10 mins it reset and I need to do the process always! It very annoys! Did someone had this problem? |
Outside has been about -8 so that is the smog. But and I think that valve springs needs to be replaced.
My car has the same noise if i open the oil filler cap.
Originally Posted by garcijav
(Post 1495411)
You drive with that sound? |
Since I bought it in 2011. The official BMW shop told me that the noise is normal.
Donīt worry. |
