bmw 5 series 2005 lights
iv got a e60 2005 bmw, i wanted to change the light bulb because it gone, i paid £50 xenon lights marker kit, i tride to fit them but i couldnt because i dont have xenon lights in my car just normal halogen light bulb,
i wanted to no if i could change halogen light reflectors and wires in the headlamp to put xenon light in the same headlamp, can any one help
Sorry I'm having a hard time understanding....you have regular bulbs? Yes you can add HID just make sure you buy a kit that has the resistors so you do not get errors. Should be around $50 or so for the entire kit. I would personally go with 6000K to 8000K. Now, If you are wanting to change the halogen light reflectors (Im assuming you mean the silver backing in the headlamp) that is a no-go. You cannot open the headlight. If you do not have projector lamps, you just do not have them.
Keep in mind you may have to do some retrofitting of the actually bulb in the housing if you have H7's etc. It's not impossible and it's not a hard task to do either.
