Blue smoke out of exhaust ??
Old 02-17-2011, 02:52 PM
luigi524td's Avatar
Have you had your oil services done regularly? I've had 3 high-mileage V-8 BMWs (140K to 240KK miles) and valve seals were never a problem. The oil separator (aka PCV thingie - can't remember the exact part now) had to be replaced on two of them ... gave symptoms like a vacuum leak ... lumpy idle ... some exhaust smoke.
What DavidF wrote a couple of posts back ...
Old 02-17-2011, 05:32 PM
X5_Rob's Avatar
Originally Posted by DavidF
There are other causes with BMW engines other than the valve guide seals. The #1 cause of oil burning is the crankcase ventilation valves. The V-8 has two - one on each valve cover. Inspect and/or replace the ventilation valve diaphrams before you do anything else.
David - would the cvv also be referred to as the oil diverter valve? My 530i was running very rough and smoking up a storm and dealer stating needs the ODV valve replaced.
I've been searching high and low for DIY info and haven't found much...
Thanks,
Rob
2005 530i
Old 02-18-2011, 04:25 PM
Isaiah_Charles's Avatar
Originally Posted by turboawd
What oil are you using? The burning oil could be affecting your o2 sensors.
Castrol 0w30
Originally Posted by luigi524td
Have you had your oil services done regularly? I've had 3 high-mileage V-8 BMWs (140K to 240KK miles) and valve seals were never a problem. The oil separator (aka PCV thingie - can't remember the exact part now) had to be replaced on two of them ... gave symptoms like a vacuum leak ... lumpy idle ... some exhaust smoke.What DavidF wrote a couple of posts back ...
Since I got the car i've changed the oil every 5k miles if not sooner....
My question is there anything I should or should NOT be doing, like can spirited driving make it worse I do plan on fixing it within 2 weeks but I dont wanna worse the prob or in this case is the damage one ? Should i dump some Lucas in there???? help guys
Old 02-18-2011, 09:26 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
Originally Posted by Isaiah_Charles
Castrol 0w30
my main rule with all engines is to always drive lighty until the engine and oil is warmed up.
revving an engine on a cold start, or driving an engine hard when cold, will shorten the life of the engine.
Old 02-19-2011, 07:11 AM
Never do I, I dont abuse any of my cars like that
Old 02-19-2011, 03:02 PM
jrsamps's Avatar
My Ride: 06 530XI Sapphire Black, Black Int. 6sp, Cold, Prem
Never a good sign - sorry dude
TopPMP
08-10-2020 04:15 PM
umichchris
12-07-2015 03:33 PM
PelicanParts.com
07-23-2015 12:50 PM
carid
07-18-2015 01:18 PM
Quick Reply: Blue smoke out of exhaust ??
