Blown Turbo? Stuck open Waste Gate? Vaccum line?
Old Sep 11, 2015 | 06:03 PM
ilovemye60's Avatar
My Ride: 2008 535i LCI
Unhappy Blown Turbo? Stuck open Waste Gate? Vaccum line?
Hello everyone, I am hopeful that someone out there can give me some advice. Complete noob and trying not to get took for a ride by a mechanic.
I was driving my 2008 535i the other day and I had a code throw for Misfire in 1. I replaced the coil and it was fine for another two days. Then Misfire in 5, replaced bad coil and was fine for another day. Now out of nowhere it sounds like a huge boost leak under the hood, I can hear the turbo blowing right out. Decided to run it to see if I had power real power loss and it went into limp mode. Took it to him to scan and a couple hours later he said the turbo is bad.
My question is can someone tell if a turbo is bad without actually taking it off the car and examining it?
If my turbo is gone so be it, i will replace it. Should i take to $tealer and get second opinion for 150 USD?
Lastly if the turbo is lost and I am not smoking how long is it safe to creep around driving? I have been keeping uner 3500 rpm best i can short shifting keeping out of boost, but how long can It drive like this? It does not go into limp mode if I drive normally.
Thanks for any advice/replies I really appreciate you even reading this.
Old Sep 12, 2015 | 04:50 AM
DanL's Avatar
My Ride: 535i M Sport
Model Year: 2010
Sounds like you have a cracked charge pipe which is a common problem with the N54. Google 'cracked charge pipe n54".
Old Sep 12, 2015 | 04:58 AM
ilovemye60's Avatar
I was trying to find a video for this just now and seems I can't find any that actually have the engine running showing what it sounds like. I am hopeful it is chargepipe but my car sounds exactly like this:
If it is the turbo 100% should i replace both and save from having to pay to swap out the other later on when it fails?
I am going to feel around on my charge pipe to see. I will update later today. Thanks for the help.
Old Sep 12, 2015 | 11:45 AM
Impac's Avatar
My Ride: 2008 BMW E60 535i
Model Year: 535i 2008
I dont think its turbo check all off your connections before you start throwing $$$ check chargepipe if its not cracked check FMIC connections, check air filter box, check vacuum lines
Old Sep 16, 2015 | 08:19 PM
illogic847's Avatar
My Ride: 2008 535xi
If it was the turbo you should be getting blue smoke and the smell of burning oil. Check all the stuff mentioned above.
Old Sep 17, 2015 | 03:28 PM
ilovemye60's Avatar
Talking Solved
When I took it in to have a code checked it seems my brilliant mechanic left the diverter valves unsecured and the one closes to the firewall blew out of the socket. I guess when he did the simple coil job for me the young kid they got their forgot to secure the diverter valves again. Well problem solved, thanks for the help everyone.
Old Sep 17, 2015 | 04:12 PM
Gregm's Avatar
My Ride: 2010 535i X-drive 6MT M-Sport
No idea why he would have to take the diverter valve off when replacing coils....? Should be able to remove the intake trim off and just remove the coils. 10-15 minute job.
Old Sep 17, 2015 | 04:18 PM
ilovemye60's Avatar
Was thinking this myself, honestly I think he was trying to screw me. Or the kid working on it was literally a freaking moron and was taking crap off he didn't need to. I am all for kids learning but not at the expense of my vehicle.
Old Sep 22, 2015 | 06:52 PM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
I'm sorry for your lost bro
I destroy my front turbo a year ago. That is the same sound i was getting after it started to shave down the fins.
Until one day i got sucker punch at 6am on my way to work....
Smoke everywhere at had to rush the 10 min drive to work.
To park the car until further notice.
Check out my car back then...
Attached Thumbnails Blown Turbo? Stuck open Waste Gate? Vaccum line?-img_0127.jpg   Blown Turbo? Stuck open Waste Gate? Vaccum line?-img_0122.jpg
Old Nov 10, 2015 | 07:48 PM
quattromeister's Avatar
My Ride: 535xi wagon
Engine: N54
Default Help! '08 535xi N54 77,5k Miles Blue Smoke
I hope someone can help me....
In reading endless threads here I could be a number of things...
1. Valve cover
2. Charge Pipe
3. Turbos.. ( I hope not)
I bought the car with 64,000 miles on it and otherwise is a nice car. Runs strong, no stuttering... get about 17-18 mpg in city and 24 on the highway.
Oil change 1,000 miles ago. 5/20 will have it changed to 5/30 as required.
1qt of oil 235 miles
77,500 miles on car
crankcase pressure test at 7.5mbar, spec is 21mbar max
Fault survey revealed - DME faults for o2 sensors and low pressure fuel sensor.
29F3 Fuel Low Pressure sensor, electric
2C7B Oxygen sensor after catalytic converter signal
2C2D Oxygen sensor before catalytic converter: Coasting mode stuck
I do smell burning oil at times lightly in the car or from the area of the windshield.
noticed that if I have the car on an down hill (engine lower than tail pipe) and rev the car for 15 seconds at 1,500 to 2,000 RPMs I get blue smoke.
Thanks in advance for your help.
jcolley
Oct 14, 2015 08:04 AM
Rudys/1232
Aug 27, 2015 03:32 PM
funglenn
Jul 11, 2015 03:45 AM
aarong15
E39 Discussion
Jul 9, 2015 07:01 AM
JWMich
Jul 7, 2015 06:13 AM
