Blower Fan Speed not working on some settings
Old Jan 2, 2010 | 02:20 PM
jgbmw's Avatar
The fan dial control has 9 manual settings. I noticed that my fan speed doesn't increase at setting #5 and above. The MAX function doesn't work as well. Heater/AC temperatures seem to be fine; all other climate settings seem to work fine too.
Any ideas? Thanks
Old Jan 2, 2010 | 02:24 PM
phocker's Avatar
Did you look into the microfilter?
Old Jan 2, 2010 | 02:35 PM
jgbmw's Avatar
Are the microfilters on each side in the engine compartment near the window? I took the driver's side out to check a rattle but put it back in place.
Old Jan 2, 2010 | 02:49 PM
Sanj's Avatar
I'm sure somebody mentioned the same problem and the cause was the battery as it would'nt let you go to the higher setting's because of the battery was weak.
Old Jan 2, 2010 | 04:28 PM
jgbmw's Avatar
I just checked the MAX function again after it warmed up in the garage for some time. It worked this time. This functions seems to be disabled at a predetermined outside temperature (winter). Although the blower did not increase at the level 5-9 setting; only level 1 through 4 make adjustments on the blower speed.
Old Jan 2, 2010 | 05:11 PM
phocker's Avatar
I believe there are 2, one on each side (driver and passenger). I know i need to change mine every now and then it makes noises when i adjust the fan speed to a higher setting.
DavaiLave
Aug 2, 2022 02:16 AM
i6YouNot
May 19, 2015 02:40 PM
rackhacker9275
26
Apr 16, 2015 08:13 AM
skidster
Mar 12, 2004 08:29 AM
