Bleeding the cooling system
My Ride: 2004 530i 6M
I have a 2004 530i with the M54 engine. Could someone please tell me the coolant bleeding (removing air from the cooling sys) procedure?
Thanks
Greg
Thanks
Greg
My Ride: 2015 535D M Sport
I have a V8, so I can't tell you for certain for the e60 6, but on my '98 528, there is a bleed screw on the black plastic thermostat housing (we used to call it a gooseneck) and you simply open it up a bit to let out any air and close it back up when all you get is coolant. Don't over tighten! I suspect your engine is similar. If you still can't figure it out, try google.
My Ride: G30 M550i
Model Year: 2018
Thanks
Greg
Thanks
Greg
Master_RA__Draining_off_and_topping_up_coolant__M54_.pdf
Originally Posted by Rudy' post='847881' date='Apr 15 2009, 09:34 AM
PelicanParts.com
07-23-2015 12:50 PM
PelicanParts.com
07-23-2015 12:41 PM
