Bizarre Parking Lamp Message
My Ride: E60 525ix, E39 M5, 350Z
Hey guys,
So this is random. On my wife's 2007 525xi she is having a message stating "Right front parking lamp malfunction!"
Here's why this is weird:
As if all of this isn't weird enough - the message will annunciate three, four, five times during one drive cycle! That's definitely not supposed to happen. If a bulb fails, the system annunciates this ONCE and it remains in the stored errors indicated by the /!\ in iDrive. It is definitely NOT supposed to keep bugging you during a drive.
Does anyone have any ideas? Also, what bulbs are we talking about here? I am under the assumption that it is the "Angel Eye / Halo's" that are considered front parking lights.
- The headlights are DEPO aftermarket units that I installed roughly a year ago. The problem only started up around a month ago.
- The DEPO headlights are supposed to be "Error Code Eliminating"
- On top of that, I coded off the Cold, Warm and Start Checks for the parking lamps (Total of SIX "nicht_aktiv" commands for left and right side
- The LCM took the re-write, as I downloaded the LCM code and it shows that they are in fact "nicht_aktiv"
- No bulbs are out.
- It's only the front right side that has an issue, with the same bulbs and hardware on both sides
My Ride: 2006 525i stick
Model Year: 525i
man i got some Umnitza lights and i have the same message, i dont know if it is actually something in the wiring but it was not lighting up the angel eyes so i ran a jumper wire. good luck on finding the solution.
All good ideas. I'm gonna mess with it in more debth this week and I will post back what ends up working. Just so weird, since I have everything coded off...
So get this... I unplugged the passenger side headlamp and found the two wires that feed 12v to each angel eye ring respectively - add a load resistor - and STILL am getting the Right Front Parking Lamp error message!
I'm gonna try resetting the LCM tomorrow through DIS/GT1. I'm out of ideas after that. This is so beyond annoying I cannot even begin to articulate. Stay tuned. I will find the issue!
So I have a similar issue, not sure if i should create my own thread or not.
I started getting the left daytime/running lamp error about a month ago. Im currently using the h8 lux bulbs from n54 tuning. i checked the angel eyes and its working. I dont get it. is there another bulb that could casue this error?
i have an LCI 2008 e60.
last time i checked my highbeams were emitted from the same projector as the main/dipped beam. is it not bi-zenon? i have adaptive headlights.
At first i thought it was a marker/peanut bulb but couldnt find it. then i thought it was the inner bulb that turns on when i turn my steering wheel? but that seems to work so i don't know. i've only had this car for a year. today and some other days it does not show me that error. its really confusing.
