Big Brake Kits or Caliper Upgrade for Xi vehicles
I came from a E92 335i to the 535xi and the difference in pedal pressure is killing me. I've been looking at all my options in regards to upgrading my brakes on my 535xi. I'm not excited by the general lack of aftermarket support of the 535xi so I'm debating going custom ( a well planned and thorough custom setup).
The setup goes as follows:
Drilled stock sized rotors (a vendor here sells some)
Wilwood 6 piston and 4 piston calipers for the front and rear respectively
Custom billet caliper brackets
AMS SS brake lines
My questions are:
Has anyone else though of this?
Did I miss the a BBK that fits the Xi?
Is a caliper upgrade really necessary? Can anyone vouch for just brake pad/rotor upgrades?
Thanks in advance. I did a search but I couldn't turn up anything really comprehensive. If you find something tho please share!
-Phil
AMS SS brake lines
My questions are:
-Phil
I've looked into it, but found nothing out there. I've ended up getting driller and slotted Centric Premiums with HPS pads, OEM sensors and kept the lines stock. Works great. OEM brakes fade like crazy in heavy use, even though in daily driving they weren't too awful. These are cooler, so they don't grab as firmly when cold, have to warm them up. When cold they are a little better than OEM, but when hot, they are friggin AWESOME! It isn't a BBK, sure, but I figured cost wasn't worth the benefit.
See V thats what I was thinking. I didn't think a BBK was truly worth it.
I believe our front brake rotors are 320mm which are a respectable size. Therefore, going with cross drilled rotors and pads should see some kind of upgrade. I wanted to know if anyone wanted more clamping power while stil being able to use a 17 or 18 inch rim.
I will look into Stoptech. I checked out Modbargains online and I didn't think they did. Then again I wasn't sure either. I think I'm just mad at how bad the 535xi offerings are vs the 335i's
My Ride: 06' BMW 530xi
here's the part numbers http://extranet.soleniuminc.com/Cent...6&m=31&mm=2803
yeah because your previous car was an i not xi .. even the 535i has more options than the 535xi, we are limited to certain brands and products :/
Edit: The link shows the part numbers for my car 2006 530xi, not sure if its the same specs as the 535xi?
My Ride: BMW E-60 530I
I ran into those.
However, KSport does not do their homework. A member on here was interested in coilovers for their Xi and upon asking KSport about fitment, the KSport rep was not aware of the Xi's differences in suspension tolerances.
Thus I won't spend 4600+ on a product from a company that does not ensure fitment to each unique application.
I'm either going Stoptech if I like their application or custom. Truth be told, I just want responsive brakes that don't fade so rapidly.
So to conclude, I recommend you save your money for something else, and just try out the R1's with some semi-racing compound pads. Tap Michael @ Acute Performance - he's got the best deals and he knows a GREAT DEAL about this stuff (he tracks some of his cars regularly and uses the products he sells
