5Series.net - Forums
-   -   Best Reverse Bulb Option (https://5series.net/forums/e60-discussion-2/best-reverse-bulb-option-130396/)
silveralty Mar 31, 2013 01:54 PM
What is the best option for reverse light bulbs? I am looking to upgrade to L.E.D., but cant find any posts.
I am not interested in upgrading to HID.
Any opinions?
ETNav382 Mar 31, 2013 08:00 PM
My understanding is that while the LED bulb appears bright, it doesn't illuminate anything really.
C_o_s_m_i_n Apr 1, 2013 12:07 AM
Don't be so sure. :)
http://img577.imageshack.us/img577/4880/dsc00345pq.jpg
Del64 Apr 1, 2013 01:59 AM
Originally Posted by C_o_s_m_i_n (Post 1497634)
So, What LED did you go for?? :)
C_o_s_m_i_n Apr 1, 2013 02:19 AM
10pcs 0.5W 90lm white LED in each lamp. :)
In the picture, the passenger side lamp has the stock bulb, for comparison.
paran Apr 1, 2013 04:11 AM
Putco Stick 194 Wedge LED Bulb - T-Type
Putco Stick 194 Wedge LED Bulb - T-Type - White - 2 Pack Putco Lights P280003W-P
PUTCOŽ - BMW 5-Series 2006-2010 Back-up/Reverse Light Replacement LED Bulbs
Made in the USA; top quality.
pcy Apr 1, 2013 04:59 AM
Why not Putco 230194W-360 LED?
Same price range and I'd think 360 degree bulbs would be better, no?
paran Apr 1, 2013 05:29 AM
Look here :
http://www.putco.com/documents/WhyLEDSpr-2011nd.pdf
Plasma LED Bulbs by PUTCO
Stick LED Lighting by PUTCO
LED 360° Premium Replacement Bulbs by PUTCO
It's not the number of LED modules, but the lumen rating, and quality of the module that matters.
Their made in the USA, single LED module products, use a super high quality Nichia LED module.
I would call Putco and ask them for actual lumen output by product type.
Your brightest (and most expensive), CREE flashlights, have only one LED module, whereas the cheap, Home Depot, flashlights, contain 10, 20, etc LED modules.
In general, the more LED modules = lower quality, lower lumen count, lower price.
Putco is the best LED mfg'r outside of BMW's LED interior light kit.
I use Putco (made in the USA product lines) over everything else out there. Putco also competes with the hundreds of Chinese Co's putting out BMW LED light kits, but these are the products NOT made in the USA.
Del64 Apr 1, 2013 08:21 AM
Thanks guys, very interesting indeed :)
C_o_s_m_i_n Apr 2, 2013 12:37 AM
Those Putco LED's put off 100 lumen . :) Really nothing for a reverse light.
The LED's i used in my reverse lamps also use a 3.3 ohm resistor / each LED.
10 LED's/ each lamp... put off about 900 lumens.
And there's room for more light.
_______
My point. :)
