Benz wheels
Old Apr 9, 2010 | 06:13 AM
Ellicit's Avatar
Anyone know if Benz CLS wheels will fit on my 530i sport package?
I mean these are not OEM benz wheels, the wheels was originally bought for a Benz CLS
front is: 20x9
Rear is: 20x11
Old Apr 9, 2010 | 06:22 AM
sdg1871's Avatar
My Ride: See my signature
No they will not fit. The CLS's wheel bolt pattern is 5 x 112. The E60's wheel bolt pattern is 5 x 120. I would not use wheel adaptors to try to force a fit -- not safe IMHO.
Old Apr 9, 2010 | 09:32 AM
Ellicit's Avatar
thanks! the search continues =D
Old Apr 9, 2010 | 09:38 AM
Ellicit's Avatar
e46 M3 will fit on my car right?
20x10
20x8.5
thanks
Old Apr 9, 2010 | 10:35 AM
ev1066's Avatar
Pretty sure the m3 wheels fit the Xi models better because of the offset.. Not sure how they will look on a non xi
Old Apr 9, 2010 | 01:16 PM
Ellicit's Avatar
maybe I need some spacer?
Old Apr 9, 2010 | 01:27 PM
Tarhee's Avatar
My Ride: 545
ya like a 20mm for front and back.
Old Apr 9, 2010 | 02:16 PM
tiangco.a's Avatar
20x10
20x8.5
thanks
They will fit but you will need to run spacers on the front.
Old Apr 9, 2010 | 02:20 PM
TakmaN's Avatar
My Ride: 2005 BMW 545i
Rear offsets should actually be fine if it's from an E46 M3 and they are running more aggressive offsets. Then it should be 10-11'' wide rear wheels with +20-25ish offset. The front offsets are way higher than our cars though. You'll probably need a front spacer to clear the struts on the inside. Other than that they should bolt right on.
Old Apr 12, 2010 | 11:25 AM
Ellicit's Avatar
Do you guys recommend putting on 20mm spacer? any safety concerns?
