Belts
Old 09-12-2012, 01:35 AM
kskane's Avatar
My Ride: E60 M54
Model Year: 525i 2004
Guys, what is the lifetime of all the belts (alternator, AC belt etc) on a BMW 5 series? Or should I ask if these needs to be replaced at certain KM's?
Old 09-16-2012, 06:48 PM
Ceenit's Avatar
My Ride: 525
I had mine replaced at 60k (5 years). I was having some other work done and it was just easy to get to.
I was amazed at how cracked my old belts were at just 60k, so I'm glad i had them done.
Old 09-17-2012, 03:50 AM
crewzer's Avatar
I can't say that I've found any official BMW guidance on this topic. Mike Miller (Old School Maintenance Schedule) recommends changing OEM BMW serpentine belts every 60K miles, and Bavarian Autosport's E60 maintenance schedule recommends an interval of 4 years or 60K miles.
I changed My E61's serpentine belt at ~47K miles (~6 years).
Your e60's M54 engine has two belts. Change instructions (text and pictures) are in the Bentley service manual. Keep the old belts for emergency use.
HTH,
Jim / crewzer
Old 09-18-2012, 06:36 AM
azn_outkast's Avatar
n62 engines change every 3yrs or 40k miles...trust me its worth the change. easy to do ha.
Old 09-19-2012, 05:21 PM
kskane's Avatar
My Ride: E60 M54
Does anyone uses OEM belts or only BMW?
Old 09-20-2012, 06:02 AM
Wolrab's Avatar
My Ride: 545i 2004, SMG, Sport, Nav, Logic-7, Bluetooth phone retrofit
In my humble opinion (which many disagree with), there's a list of low-cost stuff that you just might as well get from the dealer. There's always a risk of getting an off-brand part that won't last, and there's little to be gained by sourcing this stuff somewhere else. I'd guess that's particularly true for you, since you don't have access to multiple USA OEM sources. My list is something like this:
  • Belts
    Filters (except cabin air - ridiculous prices and won't cause damage)
    Oil
    Antifreeze
    Gaskets, O-rings, other seals
    Vacuum hose
    Fuel hose
    Fuel hose clamps
    Fasteners, clips, etc.
There's endless debate about spark plugs, since the dealer charges over $20 each. Take your pick.
If you need camshaft/crankshaft position sensors, go to the dealer.
Vman33
03-14-2022 04:43 AM
BuddyB
08-17-2017 12:48 AM
jhawk19
09-07-2015 12:11 PM
ST JAMES
09-04-2015 04:54 PM
ronmexico
08-12-2015 06:02 AM
Quick Reply: Belts
