Battery question
My Ride: 2004 530i 6M
I have two issues with my 04 530:
1. I'm getting a low battery message
2. My battery and surrounding area is covered with a thin layer of orange dust... WTF? and there's a little bit of
rust (some paint peeling) at the bottom of the battery compartment.
And now for the questions:
1. Can I pull out the battery to charge it? At the same time I want to clean up the rusty mess...
2. Will there be issues after re-installation?
Any help would be greatly appreciated
Greg
Greg
My Ride: Bmw 530d 2004
Greg
Greg
2. I haven't got any...
Originally Posted by Anzafin' post='617493' date='Jul 6 2008, 02:21 PM
1. Yes
My Ride: Gone Waiting
Originally Posted by slickE60' post='617498' date='Jul 6 2008, 02:27 PM
Would anything need to be reprogrammed?
edit: Ok, I didn't know about active steering
![Blush](https://5series.net/forums/images/smilies/imported/blush.gif)
edit2: vishwen, do you really mean reprogramming or just reset or something else?
Originally Posted by vishwen' post='617499' date='Jul 6 2008, 02:29 PM
If you have active steering you won't be able to do that
Originally Posted by Anzafin' post='617500' date='Jul 6 2008, 02:29 PM
I think if anything needs to be reprogrammed, there would be something wrong in a car. So no...
edit: Ok, I didn't know about active steering![Blush](https://5series.net/forums/images/smilies/imported/blush.gif)
Rust in battery compartment is a telltale sign that needs to be investigated! The orange dust ... I don't have a clue what that might be.
Check the vent tube to be sure it is venting properly and isn't causing caustic vapors to collect in the battery compartment area and cause corrosion. Also check to be sure that battery acid isn't leaking anywhere. Any spillage and corrosion should be cleaned up, neutralized (a past made with baking soda is one way). Then repaint any areas that require it before you replace the battery.
You might find that personalized settings (radio presets, etc) may need to be reprogrammed.
My Ride: 2007 Sapphire Black Metallic 525i. Beige Dakota Leather, Premium package, bluetooth, BMW Assist, Xenon adaptive lights, Sirius radio
