Battery problem ?
My Ride: 2006 525i, Premium,Cold,Xenon Packages
Guys,
Recently my battery died.. I researched online and found that DL-49 (http://www.autozone.com/autozone/par...dentifier=4490) is good alternative for $110.. installed it , car is running fine. Now after couple weeks, I start hearing horn once in a while during startup of the car.. sometimes the horn is on for couple seconds until I turn off engine.
Is this a sign the new battery is wearing out? Debating if I should just replace it w/ OEM battery (61 21 6 901 815) for $250?
Check battery voltage before you start the car and if can - during to make sure battery is not being discharged by faulty electronics in your car.. or go to autozone and they will verify it for you for free...
I am sure people will tell you that it is because you have not registered your battery..if replacement was done properly (with backup to prevent any unnecessary resets or glitches during battery switching)
I don't think it has anything to do with new battery type (OEM vs autozone) - if it was it would show up right away - not after 2 weeks.
but that is my personal opinion...
Guys,
Recently my battery died.. I researched online and found that DL-49 (http://www.autozone....Identifier=4490) is good alternative for $110.. installed it , car is running fine. Now after couple weeks, I start hearing horn once in a while during startup of the car.. sometimes the horn is on for couple seconds until I turn off engine.
Also does this battery come w;/ proper connector to hook up that pipe? The DL-49 doesn't have enough left to attach that pipe.. also it is much smaller than OEM battery.
I wonder w/ the one from pepboys Bosch is good fit and does attac to the pipe
Does it connect to the pipe fine? The OEM has the pipe outlet on the side of the battery, where as the Duralite - DL-49 has on top, so the pipe doesn't stretch all the way.
Lots of posts about registration and if it / or does not work. You decide. As for battery choices check ( since you're in NJ ) PepBoys for their newspaper / flier coupon for $30 off a Bosch Battery. If I recall their regular price for a group 49 / 110 AH battery was about $100/exchange and it is a perfect match for the OEM BMW battery (physically and by capacity - just another option for you!
![](http://img94.imageshack.us/img94/8306/pepboys.jpg)
