Battery jumping?
My Ride: '06 550i
'84 Nissan S12 Turbo
I need to jump my other car off (non bimmer), and was wondering is it safe to use my 550 as the jump source? If so, would I use the + terminal under the hood to connect the + cable to...and as far a the - cable, should I ground it to the chassis? Or is it better/ easier to jump directly off the battery in the trunk?
Thanks
Thanks
Thanks
Thanks
Originally Posted by craigm1841' post='771671' date='Jan 19 2009, 02:55 PM
Either way you are safe. the positive terminal under the trunk essentially serves the same purpose as the positive terminal on the battery. Make sure you find a solid ground though, a painted surface may not due the trick. the neg on the battery terminal is a sure thing.
My Ride: '06 550i
Originally Posted by craigm1841' post='771675' date='Jan 19 2009, 02:57 PM
hook up the positives, hook up the neg battery term on the dead car, then try a ground on the bmw, if your car seems to lose power, it is, voltage is dipping due to power transfer to the dead car. this means you have found a good ground clip on and start the dead car
sorry for the post whoring. contrary to popular belief it is safe to hook up the negatives before the positives. i was trying to reply fast because usually a dead car is a time sensative issue. its the problem you find when you are running 10 mins behind schedule...
Originally Posted by ktlocklear' post='771676' date='Jan 19 2009, 02:57 PM
Thanks...I feel like a big dummy asking such a simple question for a simple task.....but with how "high tech" the electronics seem to be on these cars, I'd rather be safe than sorry
power is power is power when you are talking about a primative 12v source like a car battery. if you are unsure, def go battery to battery. i am new to the high tech bmws, this may cause an error to display in your car because of the power dip, i dont know, but when you unhook the jumper cables, you should be fine again.
Originally Posted by ktlocklear' post='771682' date='Jan 19 2009, 03:01 PM
Where are the preferred grounding points on a e60? Rad support, or strut tower maybe?
hmm, teh rad support sounds like a solid ground. damn, back in the old days, (i know i am only 26) i would throw the B on the alternator bracket
I wouldnt use your E60 to jump any car... There's a HIGH chance that'll it'll cause tons of errors due to the current draw.
