battery drain problem e60 2005 HELP
![Angry](https://5series.net/forums/images/icons/icon8.gif)
can anyone help? i have a battery problem. i keep getting this repeat problem.
i have a fully charged battery and over a course of about 7 days the car slowly takes longer to turn over like the battery has not enough charge to turn the car.
once i put the battery back on i have reset all faults and i have had not any messages visually.
like i said still with no error messages the battery becomes weaker and weaker.
it is really getting frustrating now can any one help please
paul
paul
My Ride: 07 550i Sports Package
Once you put the battery back where or what? Don't quite understand that, do you mean you put the battery on a charger? Why don't you use one of those hand held meters and check the voltage of the battery with the car off and on, this will tell you if you have a battery or alternator problem.
i have given the battery a flu charge over night, the reading is 14.1 with the car running, i think this is what it should be,
i replaced the battery 6 months ago, since then i have replaced the alternator as it failed, would the alternator failing would this cause damage to the battery?
paul
paul
Awest91
09-17-2022 11:05 PM
DavaiLave
08-02-2022 02:16 AM
