Battery Drain E60 2007
1 Attachment(s)
Please can someone give me advice please
My car drains the battery within 4 hours after parking I have attaches a diag . maybe that might mean something to someone as i have no idea |
Your IBS is failing.
Will this cause the battery drain . I have disconnected the bcu and it still runs down. Does the report not say anything else or should I run the fuse test
It says you need to have someone that knows what they are doing diagnose the issue. You have electrical faults throughout the car that looks like has been an issue for a while. I would focus efforts of the LM2 and the IBS area.
Originally Posted by Wout3r@19750501
(Post 1615112)
I'm assuming you have a diesel which I didn't get the first time I looked at your post. I looked at your errors again and it seems like you need to focus on you DDE. See if the board is damaged. More than likely you will need a new one.
(Post 1615119)
Thank you |
