Battery does not hold charge
Old 10-26-2011, 09:40 AM
balbs's Avatar
My Ride: BMW
Originally Posted by lcc014
I bought my car in 2004 November, so the battery is almost 7 years old. A member mentioned he used Bosch battery from Pepboys. Which Bosch battery will work with our E60? I saw S5533B, S5572B and S6587B (AGM battery). I have not seen Interstate coming out with a AGM battery for our car.
Thanks,
I say time to change it. Personally, I would get the same OEM battery (with same rating and capacity). If that battery lasted 7 years, I would get the same one. I've never had a battery last more than 2.5-4 years when purchased from Autozone or Pepboys for my other cars. I've always done that pro-rate crap they do which is a hastle. I would get OEM, install it yourself, and have it registered by an independent BMW shop. But that's another topic...
Old 10-26-2011, 09:53 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Great, I will search the OEM with same rating battery. Definitely install it myself. I am still not sure about the registration though...
Thanks,
Old 10-26-2011, 10:32 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Just call around to find the Interstate MTP-H9 battery. 3 Firestone stores did not stock this battery. Direct Tires had it but $28x including tax. This is more than dealer price (Exidie battery). I found an online store who sell this battery at less than $200 ($172) from NY. Anyone heard or ordered from this online store: http://www.batteriesexpressinc.com/i...roducts_id=125 ?
Thanks,
Old 10-26-2011, 10:43 AM
balbs's Avatar
My Ride: BMW
Thanks,
Contact them first and see if they are willing to ship. I got mine from a local dealer since most online shops won't ship batteries since they are considered hazzardous material.
Old 10-26-2011, 11:12 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Okay, thanks.
Old 10-27-2011, 01:55 PM
bonsai55555's Avatar
So does the E60 battery need to be register or is it just plug and play? if need to be register how much would that cost???
Old 10-27-2011, 02:08 PM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
According to BMW dealer, it needs to be registered. I don't know about the cost. However, members in this forum saying that they never register their battery and have no issue with it.
Old 10-27-2011, 02:09 PM
balbs's Avatar
My Ride: BMW
I had mine registered by an independent shop for $50.
If the replacement battery has the same spec as the original, it's probably okay to not register...However, I would do it anyway.
If the replacement battery is a different spec, then I feel you should. There's a thread in the DIY section showing how you can use INPA to tell the car what the new specs are for the new battery. The car has to be told what the new rating is or else it won't properly charge the battery.
Old 10-27-2011, 02:10 PM
vkhong's Avatar
Model Year: 2010
Get the same type and capacity of battery and you should be fine. On the safe side, reset the IBS (register battery change procedure) after battery replacement. Here are the supported batteries on the E60.
HTML Code:
B080                  BATTERIE_80AH                   //80 Ah-Batterie
B090                  BATTERIE_90AH                   //90 Ah-Batterie
B110                  BATTERIE_110AH                  //110 Ah-Batterie
A090                  BATT_AGM_90AH                   //90 Ah-AGM Batterie (SA536)
A080                  BATT_AGM_80AH                   //80 Ah-AGM Batterie
Old 10-27-2011, 02:31 PM
V70Cat's Avatar
My Ride: 535XIT Space Gray, Cream Beige LeatherCold Weather, Premium, Auto, Rear Side Window Shapes, Heated Rear Seats, Park Distance, Navigation, Satellite Radio
Model Year: 08
Originally Posted by umichchris
i had similar problems (and a few additional ones too). definitely replace the battery....they are only good for 6 or 7 years anyway. i went the aftermarket route and bought a Bosch battery from Pepboys....cost me $94 and i popped it in myself....my local Steelership wanted $380 for the same damn thing....i gracefully declined lol
good luck!
I thought that the car would need to be reprogrammed after you remove the battery?
Quick Reply: Battery does not hold charge
