Battery Discharge Problem
Old Jan 23, 2015 | 12:31 AM
gjavolot's Avatar
My Ride: BMW 525d Automatic
Default Battery Discharge Problem
Hi to all,
I recently bought BMW E60 525d Auto 2004 and I love it but I have "little" problem.
One day this cold winter car won't start..
I have checked the battery and she was dead.
I got new battery, registered with DIS and now I have battery discharge problem..
Check fault codes and I get one 4548 Power Management Board Network..
I have checked MPM via INPA and it's working properly.
Interesting thing is that car is going to sleep after 15 min.. AutoGearbox light goes OFF..
With disconnected IBS and engine on, voltage is 14V, with connected IBS 14,8V..
I have researched entire google to find solution but no success..
Also I noticed that rear fusebox relay is warm when car is working, but when I check in the morning is cold..
I have these fault codes:
Code: 4203 - Glow ECU / Glow unit (unit is out, but car is starting fine on -15C)
Code: 9C78 - Heating nozzle / unknown failure
Code> E519 - Light unknown failure
Now I have disconected IBS to see battery voltage in the morning but I think that IBS is working..
I need help..
Old Jan 23, 2015 | 07:01 AM
Canada22's Avatar
My Ride: 2010 BMW 528XI, 1954 Oldsmobile Super 88 324cui
Model Year: 2010
Put a voltage meter in series on the negative side, and start pulling fuses eventually you will see it drop to 0. When it does that circuit has an issue.
There's no easy way around it.
Old Jan 23, 2015 | 07:12 AM
gjavolot's Avatar
I will try that this weekend..
today i run some diagnostics on DIS and i get that K-CAN or PT-CAN was woken 40 times in past 6 hours!!!
what modules ar tthese?
Old Jan 23, 2015 | 11:20 AM
H F's Avatar
H F
My Ride: 2005 545
When you disconnected the IBS . Did you disconnect it from the negative terminal ?
Or both the neg and positive terminals ? I think the drainage happens from the positive connection ..
Old Jan 23, 2015 | 11:50 AM
gjavolot's Avatar
IBS on positive?
I have disconnected both cables on neg.. power source and cable from positive..
I wll look tomorrow on positive..
Old Jan 23, 2015 | 12:59 PM
H F's Avatar
H F
My Ride: 2005 545
IBS on positive?
Yes the IBS has a positive wire that leads to the positive terminal for power . Go to page 30 . Disconnect both the BSD wire and the B+ connection wire from the sensor for a couple days or so ., and see if the battery drains..
Index Explanation
1 Intelligent battery sensor
2 Ground cable
3 Bit-serial data interface (BSD)
4 Connection B+
File Type: pdf
Old Jan 23, 2015 | 09:59 PM
gjavolot's Avatar
Index Explanation
2 Ground cable
4 Connection B+
ok now i got your point..
and Yes I have disconnected all cables from IBS..
Old Mar 31, 2015 | 12:08 PM
koket's Avatar
My Ride: F30 316d
Hello,
I have the same problem with an E60 530xd. I've pulled fuses out, untill I get the fuse nr 34 in glove box compartment, wich it's the CCC.
With all fuses on, after 5 minutes the car consumes aprox. 6amps of power, without fuse no. 34 it stays about 0.3-0.8 max.
I've pulled out the CCC and measured his consumption and it get me aprox 2amps(~1.5+-). What it shoud be the BMW CCC amp. consumption?
Thanks in advance.
Awest91
Sep 17, 2022 11:05 PM
DavaiLave
Aug 2, 2022 02:16 AM
DC5Series
May 3, 2015 09:15 AM
Stranger12
Apr 5, 2015 10:42 AM
E60Japanese
Mar 23, 2015 05:23 PM
