If the battery is fully charged and giving you 12.4/5v output on standby, then how long can the car sit before the battery will drain to a level where jump start is necessary? I have the old white lead-acid battery on my E60.
Also, how low does the battery has to get to i.e. 1v, or 2v or 10v at which it won't be able to start the car? |
Originally Posted by kskane
(Post 1471237)
Also, how low does the battery has to get to i.e. 1v, or 2v or 10v at which it won't be able to start the car? how low does the battery has to get to i.e. 1v, or 2v or 10v at which it won't be able to start the car? - Again too many variables to answer accurately. Condition of engine, ambient temperature, grade of oil (heavier grade of oil requires more energy to turn over engine), condition of starter motor, etc. |
Originally Posted by BimmerFan52
(Post 1471581)
how long can the car sit before the battery will drain to a level where jump start is necessary? - Too many variables to be able to answer accurately. Age of battery, condition of battery, how much is it charged during each cycle, ambient temperature.
how low does the battery has to get to i.e. 1v, or 2v or 10v at which it won't be able to start the car? - Again too many variables to answer accurately. Condition of engine, ambient temperature, grade of oil (heavier grade of oil requires more energy to turn over engine), condition of starter motor, etc. Some contributors from other forums have shared there experience as below; "100% charged = 12.6 volts 75% charged = 12.4 volts 50% charged = 12.2 volts 25% charged = 12 volts 0% charged = anything less than 11.8 volts Assuming the battery is holding the charge properly and there are no abnormal parasitic discharges, it should hold for more than 1 or 2 months." Since it is mentioned 1 or 2 months, that is 100% difference, so I am wondering if that is right, also, is that 1 or 2 months indicating 0v or 11.99v Or has, there been a person who measured the battery voltage when they needed jump start. |
I just did a battery swap in a 525i yesterday. Customer complained about having trouble starting. It was at 12.39 volts with car off and key out of ignition. And barely dropped. After 20 min it was at 12.30 v. I put the key to on position but didn't start and battery instantly dropped to 9. Something volts. I don't know exactly what your looking for but a bad battery would drop instantly once the power is on.
Originally Posted by EvolutionVIII
(Post 1471603)
| All times are GMT -8. The time now is 06:32 AM. |
