My battery was flat today... Not even the steptronic led, lit...
My car has independent heating. Searching through realoem, I've found: "FOR VEHICLES WITH INDEPENDENT HEATING NEW GENERATION BATTERY (AGM): FOR VEHICLES WITH CRITICAL CHARGE LEVEL, THE NEW GENERATION BATTERY CAN BE INSTALLED." Does anyone has a TSB about battery problems? Should my dealer replace it under warranty? |
PS I have started it with the help of another car and charged it for 100 kms. Now seems to work, but I wonder for how long.
Found mine totally dead on Wednesday morning, I'd left nothing on but it was totally drained. I gave it a charge and the car started (with active steering, transmission and ABS warnings) then later died again.. Took it to the dealer, they charged and tested and said it seemed OK. They kept it overnight, and it drained again, it tested OK but drained immediately after a recharge. On the next test their machine diagnosed a battery fault and it was replaced under warranty. If yours is like mine I'd see about a replacement.
I hope it will start today.
I had same problem whith mine and since they replaced my batery to the new generatin it?s fixed
A service bulletin to show to my dealer would be very helpful for me. Anyone?
Ooo I want a new stonger battery! even tho I dont have any battery issues... :P Anything stronger and newer catches my eye!
