Battery or Alternator????
Old Dec 16, 2009 | 07:15 AM
AP Sales's Avatar
With 115,000 miles and almost 4 years old, and with cold weather coming, I had my battery replaced few weeks ago. Just took it to my local Goodyear tire dealer. Cost $200 for the Interstate battery, installed.
Have had no issue or problems whatsoever.
Old Dec 16, 2009 | 07:23 AM
mikeg3tsguap's Avatar
i think my alternator is going aswell i have dynmaic drive malfunction aswell as the power steering goes out after about 45mins of driving check;d the fluids and its fine also my pdc and my sos seized to work..
Old Dec 16, 2009 | 01:59 PM
porsche911targa's Avatar
Originally Posted by cobradav' post='1074626' date='Dec 16 2009, 10:40 AM
Registering battery is only needed if it is a different spec then previosly registered battery. Needed to tell system how to much to charge battery. If same spec then no need to change anything.
Some alternator faults seen in BMWs include voltage spikes which cause CCC and other electronic modules to shut down to preserve themselves. This is momentary but usually leaves some fault code evidence. This a different fault mode than the more typical alternator fault of not charging the battery sufficiently.
This is true, however, I was told that the software compensates the alternator charging power over time. The logic being that it takes more to charge an older battery than a new one. All the 'registering' does is to tell the alternator that there's now a new battery and it does not need to charge it as much as an older battery. This registering essentially resets the clock and starts over. It kind of makes sense. I asked my independent shop guy if it's true and he said "yes" and they're capable of doing that too.
Isn't it a bit too much of a coincidence that all these alternator problems happen a few weeks after replacing the battery without registering it? My dealer replaced the battery under warranty, back in August, and I have not had a problem since.
Old Dec 16, 2009 | 07:32 PM
salaki's Avatar
My Ride: 05 545i 6MT
Do you know how much does an Indy shop charge to "register" the new battery.?
Looks like my Battery Tender will never off the car when the car is parked in my garage.
Old Dec 17, 2009 | 03:38 PM
I never asked my indy because BMW covered mine under warranty, but I would guess that it would cost considerably less than the dealer.
Old Dec 18, 2009 | 11:55 AM
JFiRB's Avatar
My Ride: 2006 525xi
What I also heard is if you don't register the new battery, the car will think it still has an very old battery and tries to conserve the electricity by disabling non-essential functions, which means you may get all sort of error messages.
My dealer charged me about $60 to register my own new battery. Also, right on the battery compartment, there is a label that says "after disconnecting battery, initialize the car blah blah....".
Old Dec 18, 2009 | 12:17 PM
zen68's Avatar
My Ride: '07 550i with SP, Nav, Logic7
Yes, you DO need to register battery.
http://findarticles.com/p/articles/mi_qa38...6/ai_n32129310/
Old Dec 19, 2009 | 06:27 AM
pauliehcfr's Avatar
I am having similar problems such as yours. Radio sound cuts out for a couple seconds and the interior lights will flicker. Just wondering if you have solved your problems with a new alternator before I go and drop a few hundred on a new one. Thanks
Old Dec 19, 2009 | 07:05 AM
im torn in the same boat i am out of warranty so my debit card is my warranty i know in my car its either the szl sensor or the alternator both repairs are about $600 each with labor =/ let us know if the alternator was the issue in your car
Old Dec 19, 2009 | 10:34 AM
vwvwvw's Avatar
Originally Posted by zen68' post='1076094' date='Dec 18 2009, 01:17 PM
That was an interesting article, but he didn't go into the benefits of using such a system. He only said, "... the electrical system is so sophisticated that it tailors charging as closely as possible to both the type and the age of the battery." I'd think it was to be able to discharge the battery more than a traditional charging system would, like on the F10 where charging the battery is held off until deceleration. But no one's said this about the E60.
Maybe the next time I go into the dealer I'll ask the SA about this.
