Basic climate control 2004 model - rear vent question
We've got a December 2004 E61, which has the basic climate control system (iDrive only lets you set the front centre vent to 3 different heat settings, etc). The rear centre vents just have a rotary knob to turn them on and off, there is no blue/red temperature knob.
What we've found is that the rear centre vents only ever blow cold air, apparently independent of the air temperature that's coming out of any of the other vents. E.g., the front centre vents can be set to warm, and be blowing warm air, and the rear vents will be blowing cold air.
The manual doesn't make it clear how it's supposed to work. Some googling suggests this is a design feature on some BMW aircon systems, and the centre vents are intended only to supply fresh air. But i can't find any definitive info. Tried searching these forums too...
So does anyone have the BASIC climate control, and can get warm air coming from the rear centre vents ?
I had two E60 525iA:s with the basic auto AC.
The rear seat vents gives out the "same air" as the front side ones
and they should work in the same way - same heated- or cold air.
Check the settings on the I-drive,make sure the person symbol is red. Mine was doing the same at first,I thought there was a hot and cold setting, maybe not.Also try hitting the auto setting and c if that works. After I did that it started blowing hot.
My Ride: Just gone-520d m sport- Jet Black- Dakota Leather black- AluCube interior,
On order- F10 520d SE-Titanium Silver
DavaiLave
08-02-2022 02:16 AM
