Bad condensation in headlight
Hi all,
I cant seem to get rid of the condensation in one of my headlights, iv seen on forums that it needs to be sealed, anyone know how and
What is the best way to do it, thanks in advance!
this is a sealed headlight. If you have condensaiton it's probably because the bulb covers are no on right. Take the cover off and leave it off and put car in the sun for a while. probably will take a few days for it to dry up the condensation. From there, you can make sure the covers are on fully. Unless you have a crack in the light?
You can also take the lights out and use a high powered vacuum to suck condensation out but that would my secondary option.
Several hours drive time with your headlights turned on should dry them out. Then look for loose connections at the bulb holders that could cause cold, damp air [you are in the UK] to get sucked in and condense on the colder lamp lenses.
My Ride: BMW E60
Model Year: 2016
Obviously this would be a very shitty situation, as there's no real good way of cleaning it short of cutting open the headlight.
When mine was wet I removed the round cover and open the other cover, then I propped a hair drier in the round hole and turn it on low. I made sure nothing was going to melt and I walked away. I don't know how long it took because I got a phone call and forgot about it, but when I came back it was dry.
My Ride: 08 528i TiAg Premium/Cold Weather Pkg, 20% Tint, Technic Harness, JL Audio 12W7, JL HD 750/1 and LOTS of lighting mods!!!!!
I actually would advise against this. The reason is that if the water is hard water, or other contamination, when you have the headlights on, low beam or with high beam as well, it'll cause hard water spots on the inside lens of the headlight.
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
