Bad ac kopressor ?
Have a bmw 530ia 2006 n52 engine has problems with idling, it works ok then suddenly drops idle to 550-600 rpm, it feels like a vibration in the boat, I think my AC compressor is working hard, when I turn off the fan, you increase the idle speed and the car feels great again but as soon as I turn on the fan so dips idle, the ac kopressorn work hard? will not idle increased when ac is running? my flag instead.
E60 uses a swash plate type compressor, which if I'm not mistaken does not have a clutch and thus is always engaged. There should be no change in parasitic drag on the crankshaft regardless of whether you have a/c on or off. perhaps you have an electrical system issue instead?
BTW, I noticed your screen name is "Baba". Any chance you have a brother named "Booey"? |
engelska
svenska tyska Well it's true my ac compressor is the later model, I have no fault codes have changed spark plugs, magnetic solienoider, ignition coils, air filters, etc. changed the belt tensioner today., When I turn the fan to off will raise idling and working smoothly nicely so once I turn the fan so dips idling and I feel vibrations in the steering wheel and seat, feels like a boat, And I have no brother by that name |
Is it doing it regardless of whether the car is in drive, reverse, park, or neutral?
yes that's right, you look at the tachometer dips a bit and it starts to vibrate then suddenly it goes up a little so it's ok, spällar not matter what gear it is in feels like the engine is working hard then releasing it ok works fine, as I said no Error Codes
have an old 4 cylinder golf it works smoother idle for a min 6 cylinder bmw, new tändsfitf, new airflow sensor, it is anerlunda just for this model just a heat sensor, new software for car E60 -12-11-500, new oil the automatic transmission, new air filter, car has 195 000 km, getting tired of shit, but it's fine when you're driving it's only at idle it is rough
