AWD AND DSC MALFUCTION!
Turn the wheel all the way to the left, and then all the way to the right, click to click.
This should alleviate the malfunction. If it doesn't, you will need an OBD II scanner to diagnose the problem.
But the wheel trick should work.
It could also be a battery or alternator issue. Also could be the transfer case - in my case, it was actually the servo motor and the control module of the transfer case that prompted those codes along with a AWD Malfunction message on the iDrive - but this was due to some moisture getting into the area where front passenger's feet would be. If your carpets are dry and there's no moisture in the battery compartment or the compartment under the spare, its probably just a little "gremlin".
Let us know hot it goes. Good luck.
that means your battery is low. you can reset it by turning your steering wheel all the way to the left and then steering it back all the way to the right. That should reset the error warning.
My Ride: 2007 525xi, 6 spd MT, Tiefgruen, Nav, Traffic, Comfort Access, Sat Radio, iPodPremium/Cold WX Pkgs
I had the same problem. The dealer replaced a sensor under warranty. It isn't always a battery or alternator problem but it could be. I suggest taking it to the dealer. I took a photo of the error message and the instrument cluster to document exactly what I had seen.
Good luck.
Good luck.
My Ride: USE 2008 535xi with everything
Thanks guys. I forgot to mention that this malfunction only appears when I start the car and after 50 seconds it goes away...Thanks for the info
If this is the case, that it only happens when the car starts, it is likely that the steering wheel click to click turning trick will work.
My Ride: BMW 535xi
Good luck.
Good luck.
