AWD, DSC,ABS and EMERG EBV
My Ride: 2008 LCI 535xi
Hey guys, I got this coming up about 2 weeks ago. Needed tires and brakes done on top of this. Ran the codes and the right front speed sensor was bad. Everything's been replaced and when I do a scan of the ECU there are no engine codes, the light is staying off finally. I am using a garages ECU scanner not a crappy autozone kinda one. The brake light is red, abs and dtc lights are on. When starting the car I hear the grinding noise like a gear not connecting right or a servo motor not working properly coming from the front middle of the car. I have tried moving the steering wheel right to left several times as well. Does this take a few drive cycles to reset? It had been intermittent before but now seems permanent. Thoughts?
Johnnywadd
09-03-2015 01:23 PM
