Awd/Abs/dsc/ebv/RED brake light Christmas tree
Old Oct 11, 2017 | 05:18 PM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Default Awd/Abs/dsc/ebv/RED brake light Christmas tree
Can someone help me identify the problem i replaced right Wheel speed sensor and problem not going away.
Old Oct 13, 2017 | 06:03 AM
JuniorB's Avatar
Are you sure it's the rear sensor?
Old Oct 13, 2017 | 12:37 PM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Like I said.
I replace the sensor errors are still present.
so is not the sensor.
Old Oct 13, 2017 | 04:25 PM
JuniorB's Avatar
I ment are you sure it's the rear sensor and not the front? I had a pass side restraint system pop up, but the scanner said it was the drivers side. Cleared the code, now it's fine. I put a m5 rep bumper, power mirrors and a sport wheel on the car, disconnected the ground, but still showed.
Old Oct 13, 2017 | 04:30 PM
JuniorB's Avatar
Never mind, I read it wrong, I thought it was a rear sensor, it looks like you have a few issues. Check all of them,
Old Oct 14, 2017 | 03:03 AM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
I think my problem are the 19” 128 style that i put on.
Will put the 17” back and clear codes
Old Oct 25, 2017 | 02:01 PM
JDMStevenE60's Avatar
My Ride: 2011 535i xDrive
Model Year: 2011
Any luck? My problem was due to a bad ABS pump and module, same issues as you, but non XI model
Old Oct 29, 2017 | 08:08 AM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
None... I found a abs pump in another country that I might buy if doing a wheel alignment does not work.
I have ACC so I can’t just put whatever module i find.
Old Jan 22, 2018 | 08:19 AM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Solved.
Old Nov 12, 2021 | 09:41 AM
Shaunyf100's Avatar
My Ride: 2010 BMW 535xi (M-Sport Package)
Originally Posted by Kewill0360
Solved.
How did you solve it?
