Aux problem
Old Mar 7, 2023 | 12:25 PM
stevieT's Avatar
My Ride: e60 m-sport
Default Aux problem
hi
my 2009 e60 aux works for a short time then switched back to the cd even tho im using the aux has anyone had this and how to fix it as it driving me insane
thanx
Old Mar 7, 2023 | 12:45 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Have you checked the cable & wiring
Old Mar 7, 2023 | 01:12 PM
stevieT's Avatar
no as its just started doing it
Old Mar 7, 2023 | 01:56 PM
Well that should be your stating point. Switch cable then check wiring and connector. It's a wired system so not much can be causing it
Old Mar 7, 2023 | 11:32 PM
stevieT's Avatar
checked aux wiring and cant see anything out of the ordinary
Old Mar 8, 2023 | 12:08 AM
All the way to the back of the iDrive connector. The wire should be good. I think if anything it's a connector or cable issue. Maybe the pins inside the plug wore out.
Old Mar 11, 2023 | 07:13 AM
Dj530's Avatar
My Ride: 2006 530xi (One black & one grey) 2010 X5 35d 1974 BMW 3.0CS 2008 535i, 2009 335d, 2011 X5 35d, 2008 335i FBO
Had similar thing happen to a customer's car, it ended up being the mode button on the steering wheel was sticking and causing the source to change. Hope that helps.
Old Mar 11, 2023 | 05:25 PM
donpb's Avatar
My Ride: '06 530i N52
Originally Posted by Dj530
Had similar thing happen to a customer's car, it end up being the mode button on the steering wheel was sticking and causing the source to change. Hope that helps.
How did you fix it?
Old Mar 11, 2023 | 10:58 PM
Probably take it out and clean it.
Old Mar 13, 2023 | 12:52 PM
Dj530's Avatar
Originally Posted by donpb
How did you fix it?
I used contact cleaner (explosion proof) to clean around the buttons. That resolved the issue.
