aux input
Old Dec 16, 2004 | 07:28 PM
khalik's Avatar
My Ride: 07/2004 530i 2007 X5 4.8i
Need help from members on what to do next. Picked up the car from the dealer hoping it works. This time I will be leaving my ipod with the dealer.
Good thing they did not charge me any thing for the three hours they took to install which was great.
Old Dec 16, 2004 | 11:43 PM
Gecko's Avatar
My Ride: no longer driving an E60. I drive a E92 335i now
[snapback]69854[/snapback]
Hey Khalik, no sound at all, or very weak sound?
Gecko
Old Dec 17, 2004 | 07:26 AM
pbeeby's Avatar
Originally Posted by Gecko' date='Dec 17 2004, 09:43 AM
[quote name='khalik' date='Dec 16 2004, 10:28 PM']Need help from members on what to do next. Picked up the car from the dealer hoping it works. This time I will be leaving my ipod with the dealer.
Gecko
[snapback]69885[/snapback]
[/quote]
I had the AUX fitted a few weeks ago - no sound what so ever. I'm taking the car in next week so they can fix it. I was chaged for it as they couldn't test it at the garage.
Old Dec 17, 2004 | 07:56 AM
khalik's Avatar
I have no sound at all. I will be at the dealer this morning will post back with result.
Old Dec 17, 2004 | 11:00 AM
my530i's Avatar
There was no sound on mine at all. I took it back yesterday. I'll keep you guy updated
Old Dec 17, 2004 | 11:26 AM
Flowerfred's Avatar
I've had that and it has been fixed. There was a problem with the original installation manual that the dealer downloads. If they download it now, the wiring is slightly different and it works.
Good luck.
Old Dec 17, 2004 | 11:52 AM
khalik's Avatar
The dealer just called and nothing they can do. They have called Apple to see if it should work on Canadian spec BMW which is BS.
Old Dec 17, 2004 | 12:50 PM
garehaan's Avatar
My Ride: 2011 520dA coming up.
[snapback]70033[/snapback]
This has nothing to do with apple like you already know
It is a regular 3,5mm mini-jack input where you can connect everything that gives an audio signal!
Not just an iPod.
So, Apple will probably tell them to turn up the volume on your ipod or use the belkin charger/amplifier.
On mine they did a software upgrade and after that it worked.
Old Dec 17, 2004 | 02:23 PM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
I had the same problem - actually mine worked and then disappeared the next day completely. After reprogrommaing the AUX-Input was shown in the idrive menu but there was no sound at all. My dealer did the software update again and the problem was solved.
Old Dec 17, 2004 | 04:22 PM
GER_545SMG's Avatar
If they're calling Apple tech support, run, don't walk, as far away as you can from that dealer!!!!
