5Series.net - Forums
-   -   Automatic steering wheel movement (https://5series.net/forums/e60-discussion-2/automatic-steering-wheel-movement-61348/)
MatyB Sep 9, 2008 06:31 PM
Need some help fella's..............I have realised of late that my steering wheel does not move up out of the way when the ignition is turned off and move back down when turned on like it used to, it just stays in the same position. I cna make it work if i move the steering wheel higher than i normally have it set in the memory bank. Could it have to do wiith it being in a low memorised position, i have noticed to get it down to a low position where i like it i have to hold down on the toggle to the point where it stops and then after holding down for a few momnets longer it then travels down even futher. Anyone have any ideas or explainations for this?
TexaZ3 Sep 9, 2008 07:56 PM
I'm sure your dealer have :-)
I had the same thing on my 6er, they ended up replacing the steering column.
