Automatic Parking Ventillation Feature- For WINTER??
My Ride: 2006 525i, Premium,Cold,Xenon Packages
HI,
I read about this Parking Ventillation Feature.. is it for COOL air only OR does it work for Winter weather too (i.e warm up car)? Every day I drive to office @ 8AM and Return @ 5PM sharp, so wondering if something can be programmed in car, so the warms up itself @ these times, so by the time I get in, its nice and warm
I have 2006 525i w/Premium/Cold pkgs
Depends. If on your iDrive screen you get the option for independent heating, then yes, as you have some system to warm up the air (this is definitely available in Scandinavia and other Northern European areas). Otherwise, it's only useful to cool down the car a little in high summer.
Originally Posted by coolguy' post='384213' date='Jan 28 2007, 01:03 AM
how to find that out? which menu in IDrive? I have 2006 525i with Premium/cold Pkgs
or even search this site
Originally Posted by dlevi67' post='384222' date='Jan 27 2007, 08:13 PM
Originally Posted by coolguy' post='384224' date='Jan 27 2007, 08:17 PM
Thanks Dlevi.. u rock!
You can have ventilation at any tuime but you can only have heat if there is sufficient heat left in the engine. So if you shut your engine off at 8:00AM you will not have any heat at 5:00OPM.
I know this isn't what you were looking form but for quick stops in the winter you can use the REST button when you get out, it keeps the car warm for about 10 minutes. Used it the other day and it works great.
My Ride: G30 M550i
Model Year: 2018
The independent heating feature is not offered in the USA. The REST function, as mentioned above, is only for circulating the residual heat from a car that is already warmed up so it's only useful if you are returning to the car in a short while (and you remember to switch it on before you get out...)
Take a look at the following threads for more information:
http://forums.e60.net/index.php?showtopic=33214
http://forums.e60.net/index.php?showtopic=2673
http://forums.e60.net/index.php?showtopic=5028
rice_rocket88
08-27-2015 12:10 PM
Ticomystico@gmail.com
07-10-2015 05:19 AM
