Audio upgrade: Input sensitivity on amp and DSP
#22
My Ride: BMW E60 525d LCI
twh,
If I'd have done ask you said earlier:
"(3) Now check each wire to ground. This resistance should be very large (M ohms)."
it would have saved me a lot of troubleshooting
I didn't have any auto range on my DMM and I had set the ohm to a far to low setting so I didn't see any change in resistance :'( Lesson learned!
#25
I think that you are going to need all the signal running into the Audison that you can get, even if it has some distortion on it. Try your 36 click but don't be afraid to go 42 or 45 and try it. You might end up with a better signal to noise ratio that way, less audible background hiss. See if that makes a difference.
I'll try a re-calibration with a higher output level in the weekend when I have more time.
#26
My Ride: 2009 520d Touring
Sorry to hijack, but I have an Audison Bit Ten linked up to MASK on a 2009 car and im hearing distortion pretty much independant of volume when using the head units output. If i plug my phone into the audison and listen to that in car all sounds great so i dont think the problem is with anything except the head unit. Do you have this issue?
bestofthebest
03-28-2016 02:47 PM
