audio connection
Hi I got a 2004 530d e61 and want to connect my phone to it to play music from it. I not got any aux input any where and also not showing on the I drive screen not connection in glove box .so what can I do 😁 thanks
There are some options offered in this thread. If you decide to go with the board, you will need to tap into the radio audio leads for input. Good luck!
First you will need to code AUX to you car, second you can install aux cable or aux Bluetooth, if you install aux bluetooth you can stream music from your phone without any cables |
