Attn: 6MT Drivers, does your Clutch Creak?
My Ride: 2009 DINAN 135 convertible
I saw that other thread about the suspension creaking, and that reminded me that I have been meaning to ask if anyone else with a manual has a creaking clutch. It just started doing it one day. I only notice it when it is under load, and usually just when slowly letting out into first, like at a stoplight or something. If I have the car in neutral and push the clutch in and out it doesn't do it. Very odd. Happens at different temps and regardless of shoes. The noise sounds like it is coming from in the dash, but I can't exactly get my head down there to listen as I am letting it out into first gear. I'm hoping it is just a lubrication issue and not something serious.
Anyone else have this?
My Ride: 05 545/6
-felix
Yep, my clutch also make that squeaking/creaking sound.
Not all the time, but occasionally.
Took it to dealer many times, but couldn't figure out what is exactly making the noise.
Happens regardless of shoes, but I came to a conclusion of my own:
"Noise seem to occur more on hot days"
My Ride: 07 BMW 525i Premium Package, Xenon Lighting Package, manual Transmission. Titanium Grey, 20% Tint around the back, 70% V-Kool on front.
Planned mods: Style 71 wheels with Toyo Proxy 4 tires, Sachs suspension upgrade, upgraded stereo, and many more to come.
mine was making a squeaking springy noise, quite often it will go 'cluuuuunkk', sounds like some spring noise from the clutch.
brought it to the dealer and they lubricate some spring for me, and it seems to go away.
the dealer was nice enough and order me a new spring, so they change it out for me and no more noise
actually after they first lub it the noise goes away, but they got the part anyways so i was like, 'sure, let's change it'.
to lub it should be pretty easy, check with your dealer or if you are out of warranty, just bring it to an indy and see if lubbing it solves the problem
My Ride: 2008 BMW 550i
2006 BMW X3
So yes.....
But now I have a Sport Automatic in the 550i.
My Ride: 2007 530i, white/black manual, sports package, nav, PDC, etc.
No, but I've had it in past BMWs. If it's coming from under your car (go into your garage where it's really quiet and open the door with the engine off), then it's the throwout bearing. It's expensive and should be covered under warranty.
My Ride: 520d SE
Jet black / anthracite
Advanced air con
Sun protection glass
USB
Style 244 wheels
![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
I took the car to the dealers, who lubricated the clucth pedal, but the noise came back after just a few hundred miles. However, for the last 1000 miles of so it has been quiet, so I am hoping that it has now gone for good...
I would take it into the dealer and get them to have a look.
LM
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
No.
Quick Update:
Car is at dealer for a couple things now, including the creaking clutch. They verified that it is creaking and said that with the hood up, they can hear it from the engine compartment louder than from inside the car (which is where I was hearing it). They have three techs looking at it trying to figure out what it is. They are keeping it over the weekend, which is fine with me, since they gave me a new X5 to drive.
I'll let you all know what they end up doing, but I am glad it is still under warranty. Thanks to everyone who replied above.
Further update:
Dealer felt vibration in the clutch "slave cylinder" (or something like that), so they replaced that, but still squeaks. Now, they are going to replace the entire clutch, becuase they think it is coming from the pressure plates.
Looks like I have a couple more days with the X5 (which is very nice, but I miss the fun of my V8!). Also, since my car has 48k miles on it, it will be nice to have a new clutch from a longevity standpoint, even if the sound doesn't go away. I also assume that to replace the clutch, they will have to drain and refill the tranny, right? which will be a nice bonus as well.
